Redmi K30 Series, Pro and Ultra
Ributto
I Dun know why u have issue with k20.. Many of us got China rom sets to play and seldom have issues with banking apps.. I got dbs, citibank, SCB working fine.. Nowsaday Google services is already in China rom.. Just need Google playstore..I got show the link to install Google playstore if it is not inside mi store.. Damed easy.. No worry.. Think many bro here able to help u if got issue.
Thanks, I know how to install Google playstore and services, other apps works fine like a normal phone. It just those sensitive banking apps and gpay not working, play store will also show "Device is not certified" which I think is the main reason for those apps to have problem verifying it. Did you push all google services app to system apps or just side-load it in like installing normal apk?
Channelson
that means not fully charged. if fully charged means no more current going into the phone. 100% and fully charged are not necessarily the same things.
I stop when phone say remove power.
If you continue charging, battery life will be shorten
Nakedtoes
Usually ppl install from MI store. But side load also shldnt have problem.
Channelson
How to verify play store is certified?
Thanks
Is it at bottom of play store setting?
Ributto
Thanks
Yes, under "Play Protect Certification"
Channelson
When i press those videos posted in hwz forum, it just exit this forum and didn't play the video .
Is there anything wrong with my settings that cause it not to link to youtube?
My poco f1 has no problems. Only my new k30 pro😡
Pls help. Thanks
Nakedtoes
My poco f1 has no problems. Only my new k30 pro��
Pls help. Thanks
I got no issue.. is yr mobile browser setting... go inside it got setting choice to choose open in browser or in external app like youtube.;) Dun everything blame new phone... most of the case is user issue..
MrDada
Waiting for my set. Just hoot Zoom Zoom edition... on average takes about a week to reach doorstep?
