Redmi Note 7
buggerbuggerbrinjal
Just picked up after ordering yesterday...very chio
davidwong
But bro,
You prefer what wording? Apple or Huawei? You do know you bought a Redmi phone at a Redmi price right?
Further more are you using naked or putting a casing on it? If so then the casing will naturally cover the phone so what wording?
Overall looks good but see the redmi wordings there, sian 1/2
Posted from PCWX using ONEPLUS 5T
dragonsballz
hi....just like to know for non chinese user...better to get the seller to install google play and request to set language to english before buying? Since there is no news on global rom and perhaps never since xioami now do not allow users to do that.
sumantochong
No need. You can install google play through Mi App Store to install your google play also. Steps pretty easy. Look up to YouTube if you unsure 😊
Audiology93
Download the Google installer V3 from miui forum and install it. As simple as that. Can try looking for play store in the Mi app store but I couldn't find it so I side loaded it instead.
Sent from HUAWEI Mate 20 using GAGT
garychengjw
Bookmarked... Any global set yet?
Sent from Xiaomi POCOPHONE F1 (Armoured) using GAGT
dragonsballz
Ok noted guys...thanks for the help!
lousydrinker
But bro,
Cos redmi always viewed as a budget phone, the branding itself dun sounds luxury
Like a BMW car with Toyota branding
amazingone
Huawei used to be viewed as cheap phone brand, but they have successfully transformed its image to a premium brand now.
Always believe that something wonderful is about to happen. :o
sumantochong
Redmi Note 7 still the best mid range budget phone. Good processor, reasonable price, USB C, well design ... You can’t go wrong with this one & I already owned 1 black 4Gb version ... It’s awesome! 👍
pricing aside, I just talking about redmi image n branding
