incubus22
- May 30, 2003
Pretty straight forward to me.$326 pocophone f1 64gb or $259 note 7?
Sent from Sony Xperia XZ2! using GAGT
lol i confused alr, wanted to compare pocophone with note 7 pro instead
but then note 7 pro dont know when will announce also
oh well
I am looking for good camera
sometimes good processor nt that impt
Shopee usually a lot of flash sale for pocophone F1 where it was as low as $336(around there) for 128GB after stacking coupons + coins + shopback.Saw qoo10 259 for note 7. But poco is definitely more than 326, where you see?
Recently bought the Note 7 for my dad at Shopee for $280 (6Gb/64), because of the $30 off for $300. The camera is not bad, especially if you install and use GCam to utilise Night Sight.
Use Google installer V3 from miui forum.So how you handle Google play store installation? and any problem with Whatapps & TPG data?
Sent from HUAWEI Mate 20 using GAGT
Oh..the seller helped pre-install google play. Installed a couple of apps (like firefox etc.) and it works. Haven't tried whatsapp yet but should not be a problemSo how you handle Google play store installation? and any problem with Whatapps & TPG data?
100 sets of Redmi Note 7 Pro..
Posted from PCWX using HUAWEI ALPS
China rom is ok if you're not too particular about GPS usage. Transport and apps like grab/foodpanda use it and it can take a bit of time to lock on to the correct locationSorry. Is it same like using other android phone like Samsung after install the Goggle installer? Still not very sure about Global rom and China rom. All they way..i am using Samsung phones and thinking of changing.
