Redmi Note 8
AcquiT
Incoming call i press power button to silent without reject,screen will off but the call will keep pop up till caller hang up
Wierd
Pocoyoz
$320 local set 6/128gb can buy anot?
Or black fri has better offer? :look:
i1magic
Why need to settle when you are already aiming for a high end phone just pony up a bit more money to up the storage of Mi9T pro la cos if you are looking at Mi9T pro meaning you are looking at 855 or amoled or both, why back down to note 8 pro
And if note 8 pro is sufficient for you why are you looking at mi9T pro? Very strange logic.
Unless you meant Mi9T then pricing also only 50 bucks diff.
maybe he meant expandable storage, like maybe his sdcard already have photos and videos then just put in phone can liao. the only phone with 855 and sdcard that i can remember off the top of my head is the zenfone 6, and even that has a pretty subpar (tho not garbage) ips and isnt the cheapest phone around.
if storage really an issue then can buy k20p prime with 855+, up to 512gb of internal storage :s22:
NightRaven49 is right.
Initially really wanted to feel the snappiness of SD855. But realised that with fast processing power but no or limited storage can be PITA.
From review, RMN8 Pro seems reasonably fast. Has expandable storage and low cost. So might as well give it a shot and try.
Just round out that Oppo seems not bad also. But the new Oppo Reno 2 8GB/256GB seems not bad. But it cost $790.
SpeedWeed
I just need a reasonable spare fone sometimes can use to play games on it
so i don’t need the super high specs
the pro has a nice camera
which i assume is better than my iphone XR
yeh. when the note 7 just released, it was like 330+ in sg. poco f1 was 400.
the choice was so obvious, a 660 can never compare to a 845.
Audiology93
IPhone XR has a better camera. Although 8 Pro's camera is 64mp, image processing on the iPhone XR is still much better.
Sent from LG G7 ThinQ using GAGT
chesterqw
Ye now the camera depends on software more than hardware
NightRaven49
If flash twrp recovery and magisk, is it better to flash China or global rom on rmn8 China set?
as i said on the k20 thread, there is no need to flash twrp if u plan on simply flashing other regional miui roms. but if u already have china set why still want to flash china rom again? :s22:
if ur already unlocked and planning on flashing magisk, might as well go with global.
hippoheyhey
What's the advantage of global rom over China rom?
NightRaven49
have google services preinstalled, so things like gcm push notifications, google contact sync etc will work fine with no setup, vs manually sideloading and setting up google services on china rom. also less china bloat.
however this will break safetynet if u intend to use gpay, so must use magisk to pass.
tckrto
Just received RMN8P white 128gb. The phone is heavy! But the phone itself doesn't feel like a budget phone.
teoph04
Same sentiment, first time buying a Xiaomi phone and I'm pleased with it.
Sent from Xiaomi REDMI NOTE 8 PRO using GAGT
