Redmi Note 8
NightRaven49
Erm for those who have 8T. Does it have
IR Blaster
Torch when the camera is removed
Want to get a spare for office which needs camera removed phones.
Posted from PCWX using POCOPHONE F1
ir blaster have on rn8t.
flashlight led is usually separate from the camera modules, so should be fine if u remove just the cameras. but i not sure whether the os will continue recognising the flashlight without the cameras.
shichuanhua
New arrival, Kapaver Bond x series for Note 8 PRO only
kxD7wKUm-vaCqhHDwEM8f2ZtdnfDXmZZerjvubbNJjtWHW-6wUY0jOb1QENakKb6ItOnOCUBYwun2I1c3EEtPWzr36IH5zy7DBG0riJzcxIw4irZI6hDg2masTanNn6e5tU5Jj8u7Rkk30tIJrAx5O07K-OU9EAdkuMmbbhXc5xlZAiPvrNxek6YLr-BoYGS0ZheaUIi2yqMeiPJRAYtEBjb5U1agUHGwO69JPYaBXRCofWSxp4cm6UvfLcwA7nnAvsPhKSPmymE8Tf57sMqUy4OedzDI8Ne5AxxhdSq63YWZXFFmuhXkuFxRk-XBaTLr5WkV4GbIHN9ZJtP2gtxaO3t3Cb1ZeGXgWaco4GLarsKg4WCZ54vIfC1tf0p-6S8PjJivwlc3NWJGRFlI_YJgj8XwBIy_PkO99NYyCF1JzXYG9Irc3p9a61RLx097vrUHDQQ7sYbVryGAvqLJDf0gv4r9qrI5x9hbSjh0He6knXp87trbQ0KaDlsII7HW0HRlbrICLqZw2R52blbGoaLRwjWRf3pUCO-2iNxRCUbr-kHALTyNj7q-VE8IiZc7Ts8jtzhwgSsHU6ulQUC7aDpq4i5opz1jbIzr40TZTIgZSX5Y7DUBQ37cfN4FGlafvjHw2stMgUIIrUzMsJmjoPLvD8NiwFhq_9L4HkbjtSHdNT-t7MHz6K92tMhpw6iY_rezQkiK4ACqOSF0vHDFCHHv4luauR-CsKD6oraZo-bc6nBEdNEyQ=w690-h920-no
6h4X3VplMRV40LD6AvWjqvrWY-wUz2IsMOI5xnLudQIgmP8If09t7e0J49W-krE_sDixdXWHW1LWMvIMzDuwFn2L_9F8AQXmZegjTx7c0BpOnwZ5NLCbjWiAxGT95PlPxlNweUtR5Zp40kcQg0975ObHiMVECTYGBNhE-ZH8-DSdygZMMORt6ijd2zeImPwYnAiSJtls6fpnXIMZ9B1R6kDQ8kVbm55F0I_iQpa6ToIhEJtLAP7APGW6QKeOjymGTi4JsTNerspfjNlrAcrIpztvpk520vkslzCpyKe5_OucT67O8IRNXvxFP4khPwZW9mXvfwuSL-Fj5lvbfxVP6uHmls0r05DleWuTInROSHhkAQhoLqvzs5Nw3Jz0CmAM-PrrohThOOOMY73cRh7FMRCq5HwwXcmR5cEUjt5CQyi9F017DXkw0Aok_uuUZog-ku_TLFAD07cACASgtIzKceM03enGjowU57fzq0mfXJnYfGJM6L2DsbzhOttQivoxRhHh3ym2Hoteq4uI6wd2jzSALZmG9IlfXmpIWoJCoYHRhPJO3G8qj2qCJVobjFuKPuPSjJcYRVW-m7knGGHdxJWhxwEJG7-g-AZ_hEi4EXE7ZQAYXEU-BPhooAjumXODRh7qXGGmH9P9lNkeEIqC8DFso0liETU9uSiDi_VgdCQm2q-Gp07PPPbTBV2pov0arynNxscH46xj5NzbJ9s8Jlukjv_ElaTMvKVwURpzZTw-xC4z7A=w690-h920-no
dest86
i read at the miui forums , people saying their hp battery drop a lot,mainly android system take up to 30 to 40% .is it random set or basically everyone is experiencing same problem ?
carboy00
Redmi Note 8 Pro? No issue with battery life on my unit, currently on latest Global ROM 11.0.6. On par and sometimes better than my Pocophone F1.
Posted from PCWX using Redmi Note 8 Pro Ocean Blue
GoodBetterBest
There's a label on the back of the phone "To protect your consumer rights, please keep this label intact."
What does that mean ? Cannot peel off ?
GoodBetterBest
If I turn on 2 taps to wake, would it:
- turn on in the pocket if there are other things inside ?
- consume more battery ? alot ?
Thanks !
mankind66
Ask your brother not to double tap
Will consume a little more as the software will search for double tap all the time
Thanks !
XiaoFu99
Note 8 PRO 64GB with global ROM export set at Shopee with $259.80, ok price to buy ?
kottty
Is 320 a good price? :o Which store in burlington square? :o
not sure is good price or not?for me think price is OK cos is local set.export set cheapest i find selling $293.for extra $27 is worth to getting local set with warranty.
me get from mobilehardware
Sent from Xiaomi REDMI NOTE 8 PRO using GAGT
Broadwalk
The local warranty means it is warranty from the shop locally or from xiaomi directly ? :o
