Redmi Note 9
ah keow
i was updating my redmi note 9s moments ago and before i know it, the phone was turned off. it cannnot be turned on. any experts can help?
malmal
Dont know why stuck like this for a few days. Seller said could be stuck at custom inspection, but other people bought during the 11.11 sale already received since 15 Nov 20.
15-11-2020 13:22
Parcel is in-transit from China to Singapore
14-11-2020 19:09
Your parcel is shipped from our sorting center in Hong Kong SAR, China
14-11-2020 01:36
Your parcel has arrived at our sorting center in Hong Kong SAR, China
12-11-2020 15:00
Your parcel is ready to ship from the seller
Teo Ming Ern
Redmi Note 9 = Redmi 10X 4G in China
Redmi Note 9S = Redmi Note 9 Pro in India
Redmi Note 9 Pro = Redmi Note 9 Pro Max in India
Redmi Note 9 Pro 5G (soon to be launch in China) = Mi 10T Lite
Redmi Note 9 5G (soon to be launch in China) = ?
Wah... thank you! So I should buy the Note 9 Pro cos that is the highest end phone for this range...
y2k_tay
Anyone got good screen protector for n9pro to recommend? Tried n tested good ones hor...tks...:o
wongminmin
is it normal?
redmi note 9s on standby mode....every 3 days need to charge 1 time. i use my rmn8p frequently.... 1 week only charge 1 time... :vijayadmin:
i try playing with the settings...but still.... :(
cryn79
Hi all,
I have just unbox my Note 9. After taking out the sticky protective film which protects the whole phone.
Is there another film that I need to take out from the screen? thnks!
In addition, the charger plug provided was a 2 pin, is this a standard for all the xiaomi phone now?
I bought it via xiaomi official (shopee mall) shipped from SG.
thnks for the help.
wongminmin
Hi all,
thnks for the help.
that 1 is pre-applied screen protector. u can remove it if u want to replace with tempered glass sp.
not really a standard.... just not longer an requirement to have 3 pin plug.
so xiaomi can just import sets with eu plug.
RLWZ21
Hi all,
thnks for the help.
Which 2 pins do u mean? Like China one or local?
If like local one is pretty common since dunno when.
gregory_choo
Hi all,
thnks for the help.
you took out the screen protector.
in fact it is quite good, don't have to buy another screen protector.
cryn79
Hi gregory_choo / wongminmin / RLWZ21
Thnks all for yr input, appreciate
@gregory_choo: I have not taken the screen filter out, it is too sticky. Thnks!
addict951
High Honorary Member
is it normal?
I suspect it’s the apps or some apps
I encountered the same thing wif my N9P
When I just got it, wah! 5-6 days charge once only no problem
But as I install more & more apps, the standby time got shorter
Nao I every 2-3 days need to charge liao
