Redmi Note 9
gregory_choo
is there any way to find out what is taking up all the cpu time? i have a feeling it is an app because typing on the keyboard once it is enabled is fast, it is just after switching to a window, the time taken before you gain control is very long
what is the free RAM available when this happened? you can use the bottom left icon ( a square icon) to find out.
revhappy
Sausage, cannot be one
Your N9 should be faster than my N8P.N8P also has mediatek chip. I installed 10 apps. it is still fast for me. Logically speaking, your N9 should be faster than my N8P.
I suggest you format/reset the phone and try again
Are you saying G90T 6gb ram is faster than G85 4gb ram?
I have redmi 10x which is same as redmi note 9, it is not laggy, but I don't think my phone will be faster than yours.
Sausage
immediately after the lag, when i press the square button to check, it says 1.6gb of 3gb available
revhappy
Then it is not memory issue. My 4gb ram redmi 10x also has 1.5gb available.
human_shieldz
Hmmm, rebooted phone and monitor again and after 1 week with all apps closed, available ram is slowly dropping again now to 1.4GB free, at some point, it will hit even 1GB. Imagine this is even after i set to close background apps after screen goes off.
Sausage
I got wakelock detector to see what is taking up process time but it needs rooting. Any alternative apps?
Sent from Xiaomi M2003J15SC using GAGT
revhappy
I suggest just do factory reset and install only the minimal apps. Should solve your problem. 3gb ram is not a lot. Maybe you have too many apps on your phone.
Sausage
My photos effectively brand new with less than 10 apps installed
Project_Xco
sounds like memory leak.
gregory_choo
set to close background apps after screen goes off - it only works for the well-behaved apps, it won't close all the background apps, some poorly written app or those apps with ill intention will still run and occupy RAM space.
caesium5
Looking for Screen Protector
Hi, just bought a Redmi Note 9 and a Redmi Note 9 Pro. Anyone using a glass protector that can recommend?
I went to Shoppe and the naming looks weird to me, something like Redmi Note 9 Pro Max. I'm actually confused.
Thanks in advance for the help.
gregory_choo
I thought all note9 come with glass protector film - factory installed.
caesium5
Yes, I can see a very thin sheet of screen protector but I guess it is like a very thin plastic film.
human_shieldz
Could be but its happening only after i updated to MIUI 12. I didn't factory reset though but i think most people here also never. The thing is, my Poco F2 Pro came with MIUI 12 and it's fine for most parts, then now Android 11 is buggy like hell.
