Redmi Note 9
Sausage
no one else is encountering the serious lag on this phone? Mine is totally unusable, i've switched back to using my redmi note 7 which is way faster.
aljj1996
urm so far nope, i used 9s and 9 pro, just that my 9pro batt seems to drain faster than my 9s
ZrE0_Cha0s
did u try to reset the phone? if u did and still didnt help try to upgrade or downgrade to your last known stable verison.
all else failled as xiaomi to fix up for you.
matrix05
Maybe like for poco m3, change animation to 0.5 for better response.
kazuki666
Actually is there obvious difference between RMN9S and RMN9P??? I see the former is slightly cheaper.
Sent from Xiaomi POCOPHONE F1 using GAGT
eip1234
I found that cloning data (or using Mi Mover) from old phone to new phone will create problems, one of which is the lagging issue ... So best way is still reinstall apps and sync data over via cloud storage ...
revhappy
Maybe you got a lemon. Time to sell your phone.
Sausage
i just did a reset and google automatically restored all the old apps and data.
With the same apps and data, it's still a slow phone, but after 3 days of use, it doesn't have the freeze-every-2-minutes problem anymore. It's slow but not totally unresponsive anymore.
Not sure why this happened. When I bought it it appeared to be factory new.
human_shieldz
I think goto show us the definition of slow cos some people like 1/2 second also consider it slow. Mine still seems fine. You could have gotten a bad set. Test it more and if it's still problematic then quickly send in for warranty.
gregory_choo
what is the free RAM available when the phone is idle?
I suggest going through all apps, if possible clear the user data.
go to settings - manage apps - storage - clear data.
this will erase all user data associated with the apps. do it on all not so important apps.
