Redmi Note 9
davidwong
From the note 8 thread cheapest was 268 for note 8 pro 8/128 and coupon (if you able to grab) will be even cheaper
How much is Redmi Note 8 Pro 6/128 local set now? I find that Redmi Note 8 Pro 6/128 has really decent performance and battery life. Personally, I bought the Redmi Note 8 Pro 6/128 for about $330 from a shop when it first launched.
Now is to consider which one to get for my wife.
carboy00
Xiaomi just posted they have another Redmi Note 9 series launching on 30 April online.
The Note 9S we have here hasn't launched in Europe yet so we will see it getting launched there during the event. Rumours pointing to a Note 9 Pro and a standard Note 9 being announced. Wonder which of these two will be the Note 9S we have here. No idea why they are complicating the naming scheme.
Posted from PCWX using Redmi 5 on Paranoid Android Quartz
niwde1980
anyone using note 9s experience phone restarting ?
Sent from HUAWEI EVR-L29 using GAGT
zenify.me
Previously when I had a redmi note 7 the Bluetooth connection is terrible, break off easily when connected to a TWS Bluetooth earbud. Does the note 9 series have the same issue?
niwde1980
wifey using, no issue so far
Sent from Xiaomi REDMI NOTE 8 PRO using GAGT
i use google map whole day have already experience 2 times reboot. maybe it cannot withstand long time using
Yuripa
Should be current software buggy issues. Best to wait for updates.
Need NFC get 8 Pro, want latest phone get 9s.
Sent from A New Hope using GAGT
carboy00
Give them a few more updates to smooth out any bugs. Xiaomi new models with initial builds are typically quite buggy.
Posted from PCWX using POCOPHONE F1 Rosso Red
Yuripa
but why don't get Mi9T?
No one is stopping you.
Everyone has a preference checklist, I wouldn't know what you're looking for.
Anyway, the last I heard, mi 9T got a few bug issues that might be unbearable for some users (don't ask me what it is, I stopped following this series for some time).
RollingGoodTime
Went to shop to test on the demo set of mi a3 before and encountered same issue also.
You encountered on which model?
RMN7 same as you. Will get distortion if I put my phone in my pocket. If take out and nearer to my upper half of my body will be ok
ronnie
I like the mi 9T a lot but after some consideration decided to buy the Note 9s instead. mi 9T has no sd card slot and the durability of the pop up camera raises some concern. Also the mi 9T is more expensive.
Also considered the Note 8 pro vs the Note 9s, and decided on the 9s cause of the battery. But like someone who mention, if you need nfc then don't get the 9s.
So far, like the Note 9s a lot. For a budget phone, it offers plenty of features. Just did a software update yesterday and hope that the software will hep the phone perform better.
