Redmi Note 9
Broadwalk
I see. IMHO, spending a little more for case is worth the investment. However $7.90 to $9.90 is way above my threshold for Tempered Glass.
Average tempered glass in Taobao range from RMB 1.90 to RMB 30 depending on grade.
The above average grade Temper Glass usually range between RMB5 to RMB 15 and it usually loose pack. No intention to spend so much for box and packing. IMHO
I did compared to those 1-3 dollar range tempered glass. :o However after combining the offers and deducting the vouchers the cost saving is not worth the effort. :o So I try to adhere to same supplier and vendor to minimize unnecessary shipping cost. :o
Like I shared, I paid only 9.49 dollar for the cover and screen protector inclusive the shipping. :o So I think I get the best deal by getting the best combination I can at a reasonable price. :o It is just to give me peace of mind. :o
Backlash
No worries. Such things are subjective. I am those who have the preference of buying cheap and in bulk for backup.
The KS mindset
Squaredot
change battery easier than changing lcd because the back cover held by clips
My 4X charging connection loose loose, difficult to "feed electricity" in it, must adjust adjust until fire :s13:
how arh? Is it battery problem?
Squaredot
I just order a Redmi note 4 replacement battery.:o will try to change myself then see how.:o
bro can share where u bought 4X replacement battery?
edit: I found my first redmi 1s in the drawer! :s13:
this one not working also due to battery issue :( I think it's still working.
Broadwalk
It’s at the above thread.:o
redmi note 4 replacement battery from other shopee vendor.
https://shopee.sg/XIAOMI-BATTERY-BN4...262.6000030714
:o:o:o
Backlash
For Connectors, unless it is plug and play. Soldering of new connector to the PCB will likely be required.
GrandJedi
Embedded for you, but dun know why it fails. :o
Does this come with local xiaomi warranty? Thanks.. I am a newbie
Broadwalk
Yes this shopee store is an offical store. :o Warranty will be 1 year and service center is at Funan center. :o
Currently, the best price will be 10 offset from store and 30 offset voucher where you can get from electronic section every 0000hr onwards. :o
https://shopee.sg/product/178877065/7732755442
:o:o:o
