Redmi Note 9
justln
With border so won't see air bubbles along the edges right?
From my previous experience with MiMax 3 "black border" TG SP:
Those with black borders isn't really tempered glass, it's using sticky tape and black to cover up the white edges.
The end result is that you will most likely end up with a smaller screen because the black isn't perfect.
Best is buy those SP that's slight smaller or those normal tempered glass with "oil filler", a small bottle you can squeeze into the edges. Effect might wear out after a while though.
Just received my phone before SP and case arrived. :s13:
EveMuffins
Yaya.. I saw the SP reviews, some come with one small bottle of liquid..didn't know that's oil..I thought glue.
I placed order for casing already. Now looking at SP then come 8.8 weekend will hoot Note 9 Pro once got sales. But my fingers too slow, didn't manage to grab the bank vouchers.
justln
It comes with a very basic case and SP already applied, the alignment is very slightly off but acceptable so can skip SP. :s12:
EveMuffins
But the default SP is just the plastic sheet right? I more kiasu, I will use tempered glass and flip case coz I always drop my phone. :s13:
Yep either black border or full clear but need to use the "oil" to fill up the air gaps.
Sent from Samsung SM-N950F using GAGT
I think I'll fill up the air gaps if come with the oil coz got air gaps mean got dust..then the dust will stick underneath the SP.
justln
Update firmware, install a few apps, uninstall a lot of bloat like lazada app (wtf) and... put back inside the box because flip case hasn't arrive.
Too bad my Mi Max 3 still working decently, if not the Note 9 Pro seems like a great purchase. :s12:
gregory_choo
for people like you who always drop your phone, tempered glass is not suitable, unless you find it fun to change tempered glass regularly.
allanzzz
hi is this pricing ok?
1 Year Local Warranty | Xiaomi Redmi Note 9S (128GB 6GB) | Local SG Shipping
SPECIAL PRICE ON 9 AUG $295.00
justln
If don't mind the 1 month warranty, can consider Note 9 Pro $319.
rrr2015
have anyone tried "Mi Move" to migrate from say note 8 to note 9s?
justln
Can try Wondershare MobileTrans, need to connect both sets to PC, fastest. Contact limited to 5 for free version but contact can just use Google transfer.
justln
PeasantBeing
If possible setup from scratch. Migrate may have problems here and there. I always setup new phones from scratch.
Sent from REDMI NOTE 8 Neptune Blue using GAGT
rrr2015
just interested to try Mi Mover since it's new to me. wondering what will get moved over (data & apps?).
i migrate using backup + restore before but that's for similar model. quite fuss free as almost all apps gets restored on new mobile. contacts, calendar can just sync back from google.
allanzzz
need warranty as for rough user. My max3 use until now no problem.
And can this be used for volte with tpg by entering some codes into the dialer app?
Apex01
Redmi Note 9 Pro.
ARS Digital World at S(218058)
Tel 62940786, 84411115
$296 Redmi Note 9 Pro (6GB RAM 128GB ROM). 1 yr shop warranty with receipt. Covers hardware repair. Tempered glass $5
justln
Redmi Note 9 Pro.
Looks like ah neh shop, if got issues very hard to repair.
