BBCWatcher
- Jun 15, 2010
Not true, as noted upthread. Raffles Shield A+Raffles Hospital Option+Key Rider is the lowest cost Integrated Shield plan (and rider) designed to cover private hospital care. (At Raffles Hospital in this particular case.) If you insist on an Integrated Shield plan designed for private hospital care then that's your lowest cost option.after doing some research i am still kinda lost, pardon me for the poor english/ format
1) Hospitalisation downgrade path
- currently to choose Private + cheapest rider = Prudential
What's the logic here? If you're prepared to "downgrade" in ~15 years why would you pay extra now?- eventually downgrade to Govt Class A + cheapest rider at age 40/50
Raffles Shield has an "as charged" public hospital B1 ward plan. So does Singlife, and theirs is quite excellent.- problem = lack of Class B1, however can be mitigated by choosing GE instead, however, GE is too expensive for Private, and Class A is more expensive compared to Prudential Class A
That just doesn't matter. Premiums aren't guaranteed, will definitely change, and that's 50+ years from now. You can ignore that bit.- only at age 82 GE class A will be cheaper (cumulatively) compared to Prudential Class A
Insure to the level you think you'll need to have a decent, basic (non-lavish) lifestyle, bearing in mind the payout will not be increased to account for inflation. Pick the longest waiting period the carrier offers since your emergency reserve funds should "bridge" to payout start.2) Disability Income
- GE Pay assure = 75% of salary, assuming 3k, but i am afraid if i changed job will reduce salary, so should i just buy 3k now or the currently salary, else if would i be overpaying? e.g. say i am drawing 5k now.
- problem = 180 days or 90days? agent mentioned that very little ppl claimed before for 180days
A couple questions here...![]()
3) 1M Term Insurance (standalone) + 100k Multi pay Critical Illness or should i go with
4) 1M Term insurance (rider) + 100k Early CI + 300k CI
Does your dependent need (an extra) $1 million if you were to die tomorrow? Bear in mind all your net assets would (presumably) become your dependent's assets? Also take into account inflation, the fact your parent isn't getting any younger (lifespan), and the presumed growth in your personal wealth. $1M is still a lot, actually, hence my questions.
Can you afford the CI, or that much CI? If you can't, worry about it later.
If Moneyowl offers the same product that you decide to buy, sure, you might as well get a few (it'll be a very few) dollars back.-looking at singlife as it is cheaper, not sure if should go via moneyowl
Generally not. Remember who you're trying to protect: your dependent parent. How old will your dependent parent be 39 (or 44) years from now, and what will be the genuine insurable need? You're going to be retired by then (one would assume) and with a pile of wealth that's bigger in part because you didn't buy insurance you don't actually need. So what's all this for?- currently = age 70 Multi CI + age 70 Term (total = $72k) , should i go up to age 75 Multi CI + age 70 term (92k). Is the 20k extra justified for 5 years?
Necessity, no. Cover the basics first. However, if you must purchase a PA policy take a look at the MINDEF/MHA group PA rider (if you qualify).5) Accident Plans (necessity? or not? )
You're required to have CareShield Life in your age bracket, so that question is settled.6) Careshield life (necessity? or not? )
I think you're asking about a CareShield Life supplement. Same advice: cover higher priority needs first. If you still have some budget then take another look.
