Replace home broadband with mobile plan?
RyanJ
Running one in a mancave.
Signed up for Giga 1TB data plan. $28/month. Used as wifi.
Wifi speed seems very decent, good enough to do one thing e.g stream Netflix . Dun bother multitasking doing upload/download and streaming on TV.
App monitors the usage.
Home broadband is actually reasonable and better..
But for small commercial spaces where commercial broadband is ******* expensive, sim card can be viable option depending on usage.
The_Davis
High Honorary Member
Deluxe Member
What do you mean by home broadband is reasonable?
Nowadays home broadband is crap and after my recent downtime for 2 days, looking for alternative that is cheaper and better . Paying almost $31 per month now and speed only 200mbps max :(
The_Davis
Deluxe Member
ownself do evaluation how much data needed per day for you usual practice.
est. 10GB a day should be enough for youtube and online drama and surfing whole day
If watch 2 hours YouTube enough? :(
Say on 720p
RyanJ
For a start can try let ur phone be a hotspot and switch ur home devices to the network to trial few days and see if it works.
When I upload stuffs to cloud GIGA 5g cannot support PC browser loading .. maybe other providers can.
Also TVs etc tend to stream e.g Netflix at much higher bitrates and 4k vs HD/720p for smartphones.
Ultimately depends on usage habits.
dambio
Ya… if can dual use, also double up as mobile sim ish the best 😄 save on my mobile phone sim cost also
I'm also researching abit on tis.
https://gomo.sg/mobile
I think tis 1 ok. If let's say u use 10gb on pc. Still got 300gb left for mobile. But mobile wun use tat much 1 la. But think 5g uses more data.
If got 2 simcard best. Becos troublesome to take simcard out of router😂
The_Davis
Deluxe Member
U can try let ur phone be a hotspot and switch ur home devices to the network to trial and see if it works.
What equipment do other than that 5g sim router and sim plan?
seowbin
if 200mbps max, means your router/wifi got issues la
change that first. must be si bei old liao
The_Davis
Deluxe Member
Think ish StarHub never update my plan in the backend :( still on 300mb even though they supposedly upgrade me to 1gbps
K202020K
Go hawker centre use the wireless@sgx not bad I've tried at my area. Some more gotch free ceiling fan to cool down.
