Replace home broadband with mobile plan?
Kiwi8
Deluxe Member
Good
However CMLINK, SWAP Mobile, Singtel senior now having this issue
Could it be because of SingTel's throttling algorithms when it detects the sim card being used in router as compared to being used in phone?
ridiculous?
uncle_josh
I encounter exactly the same issue as you, in my case, it is with cmlink & swap mobile.
Looks like all the new physical sim have some built-in features that work against 5G Sim router.
not sure the restarting go any thing to do with this equipment registration.
source : New Rules for IoT, eSIM, Residential Gateways and Mobile Phones
itchying
It seems like singtel can only use 4G. On eight can run on 5G. So far tested both for at least half a day network are stable
Did u also check the 5g bands around your vicinity singtel cell towers and try locking in these bands see if it works? Maybe could be singtel is trying to decomm the old 5g to move to 5g+ causing probs atm.
rayzatch
Hmm, there is only options for 5G(preferred) and 4G only. So I guess can't try out. But on the 5G preferred was the one that keeps disconnected
