Replace iPhone 4 Battery
famasutika
Looks like my existing iPhone 4 battery going to die soon. May I know how much it will normally cost for replacing a new iPhone 4 battery? At Apple and/or at those neighbourhood mobile shop?
Vynn
Buy from eBay for less than 10 usd, and DIY. You need to be careful when you dismantle your phone, especially the 4 pins.. Super fragile.
lansi23
it's still under warranty. just bring back to telco and have it replaced.
dankoo
3GS batt can be replaced quite easily....ebay for batt and replace. Just becareful to get the correct batt...
Devil_in_Blue
How do you know that your battery is going to die? How long have you had it for?
famasutika
battery also under warranty meh? i tot those wear and tear parts are not covered?
i noticed my battery going to die coz' everytime when I charge, after a short while, I'll need to re-charge again. So, think that the battery go weak liao coz' I turn on my phone 24 x 7 one.....
squid93
yupp it's covered under the warranty.
that's why many people get their battery's replaced near the end of the warranty period.
famasutika
how long does it normally takes to send back my phone to get the battery replaced? I should send it back to Apple or to my telco operator?
EVObyHKS
Hi, what is the correct brand and model to get? Also, the batteries selling in eBay are not genuine and will anything happen to the phone after installing it?
EVObyHKS
you can tell it's going to die soon when you charge it fully at 11pm and at 11am after not using it, it drops to 50%.
Hi, someone in a handphone shop once told me that if the iPhone starts to display " Charging is not supported with this accessory" when using Apple's charger, the battery is showing the sign of "going to up lorry soon". True?
Need advise on this. My iPhone recently display the above when charging and I need to replug a few time everytime to charge the phone. Battery usage drop quite alot, eg. after a full charge drop 11% in 24 hrs without using it. So, is there any problem with my battery?
famasutika
I don't get the warning message as you did, but my battery drops very fast.....
jonathan_667
Battery for iphone 3g/3gs are different models also.
PM me if you should need any help. Battery changing available. Both for
3g/3gs model. Batteries are in stock.
jq75
leaving the phone on throughout?
btw, they replace with refurbished phone when we ask for batt replacement before warranty runs out?
also where to check against the warranty period for a store set?:D
famasutika
true also hoh... how to check the warranty period for a store set ler?
