Replacement for Geforce GTX 970 HSF assembly?
Outramkia
If you're using windows 10, you can just use the reset pc function to reset back to initial os installation state
serraphine
It's a Windows 7 system (initially setup in 2012). For now I have reinstalled the latest drivers using the Custom option to uninstall all previous drivers. Will see if there's any improvement (stability) the next few days.
wwenze
I think just strap a 120mm fan with cable ties and will keep the GPU cool enough. 30 bucks can get a good 120mm fan that can be reused. Haha.
30 bucks??
Oh sorry, I still from 2003 when people paid $4 for fans.
watzup_ken
Does the latest driver support Win 7 in the first place? I recall that Nvidia stopped issuing Win 7 and 8 drivers.
ZrE0_Cha0s
Sorry to revive this recent thread but may I ask is it possible to slap same brand HSF but of different models?
wwenze
Saw a faulty GTX 970 selling for $20 on carousell but disappeared already :s13:
Only if the mounting holes are identical, the contact points are matching, and the power dissipation is similar. It works, but chances are not high.
royfrosty
Dont think it is possible, cause the mosfet/vrm area need their own cooling, apart from that the VRAM section needs their own cooling to. Most of it all quite precise location.
watzup_ken
The mounting holes are the same. However, depending on the placement of the components on the board, it may not fit. If same brand, you can check if there is a picture of the heatsink before buying it.
ZrE0_Cha0s
okay so the undying issues is still the precise location of each individual component on both board. even if mounting holes could be the same, but still have other factors like vrm and mem thermal pads.
is that correct?
watzup_ken
is that correct?
Generally same brand and model will be the safest. I think some brands like MSI may reuse the same board and therefore the same layout. But still there is a slim chance that something is different on board and may cause mounting issues.
Krabs.
ditch HWmonitor and use HWinfo64 instead
hwmonitor developers are slow to react , exposed during august 2015 when they didn't update to cover the latest sensor reporting microchip , for months many users post on OCN forums about their cpu temperature wrong and their screenshot show HWmonitor
