ment0smintz
- Jun 12, 2012
I called the apple to check if I can replace my current ip6+ since it is TLC. Still waiting for the further notice... anyone share the same thoughts?
then if it gets poorer performance over the time means its normal? cos i read that TLC is much more easily wear and poorer performance and "suay" as compared with MLC and so on and forth... definitely wants to change =( from my perspective
feel sad for those on tlc and hope apple can compensate them by extending 3mths warranty.
the saying goes, if its aint broken, don't fix it.
Need to raise the matter.. I call the apple liaoz... And the product specialist says I am the first case to raise the issue to him with this regards... I think also the Apple moderator is removing tlc issue in its community...i also feel like changing.. my apps keep crashing when i load a lot of movies on it.
Just delete 50GB of movies and it seems more stable now. Anyone else have that issue?
Cause out of every 10 customers, usually only 2-3 peeps really experience such issues. The remaining usually just "Jump on the bandwagon" without actually showing any signs of issue. My iPhone 6, 64GB is functioning fine, just occasionally minor glitches here and there.
