Replacement for Surface Pro 4
starbury
Hi guys, coming from a Surface Pro 4 that just died =(
Would like a touchscreen device, at least 13inches, and a good stylus to take handwritten notes.
Would prefer a hinge design so that I can rest it on my lap to type (which the SP4 can't quite do)
Any recommendations? TIA
Firestone
hinge type are currently of ratio 16:9 though
prob might have to wait for later refresh to see whether there are signs of trend changing to 16:10 or not
else portrait viewing is weird with 16:9 ratio
starbury
Any that you'd recommend anyways? Cos the SP4 was my daily device and need it replaced
Or any traditional laptop with excellent stylus?
trenzterra
Can try the Envy x360 (with AMD Ryzen 4000 processor) or the Dell XPS 13 2-in-1. Acer also has the new Spin 3 or Spin 5.
If you can wait a few more months, the new Yoga 6 and Yoga 7 from Lenovo seems quite promising too.
Firestone
actually wont recommend envy series. can't set a battery limit for charging
from what i understand, only their higher end models have that function
so if you want to get envy, pls get extended warranty care that specifically covers battery bloating issues
if TS wants a good touch screen type...
think thinkpad X1Y, X13 yoga, HP elite dragonfly will come to mind
but it's kinda bad time to get a refresh model, coz most likely end of year will come out intel 11 gen processor with upgraded gpu
starbury
Thanks for all the tips guys.
So if I do wait till year end to purchase, advisable to get the intel 11th gen processor models or buy 10th gen at a discount?
peterkr
I'd go for the 10th generation at a discount. The 11th gen will probably be considerably more expensive after introduction. And perhaps have limited availability.
