goodtastingsteak
- Jan 19, 2008
Hi all, I'm a noob when it comes to lighting so wanted to get some advice.
i have a LED wall light that comes with an LED driver. Everything works fine but I wanted to see if it's possible to swap out the LED to something lower wattage so it's not as bright.
I would have imagined someone could easily swap out the LED strip (maybe even re-use the casing) and I'd be good to go (or at most, also replace the LED driver?) but i have no idea and the lighting shops in geylang all said not possible.
Just wanted to see if anyone here might know.
Thanks!
Thanks!
