[Review] Hugu's Glass Guard vs SGP's Glas.tR
bikeseller
hi, do u just use the glass guard only ? or do u use both glass guard and a bumper ? or case ? can i have an insight on what case u using for your iphone
deep3lue
Check out my post here :)
I'm currently using the cheapo case because my Desmay case got damaged when I accidentally dropped in.
shouta
Can I also ask, those with glexible installed, is it worth the money to upgrade to glass guard or glass TR? Is there any significant difference?
Glas.tr has a smoother touch while swiping across the screen.
Also feels more 'protected' and gives brilliant colours
njiteb
If you have Glexible installed, you might not need to upgrade unless you have the spare cash and you prefer to have a smoother feel on the glass screen. However do note that Glexible in my opinion prevent smudges better than the Glas.tR and Glass Guard.
Hi, may I know if there's any difference in screen clarity or colors between Glexible and Glass Guard? Is it really that hard to swipe across the Glexible? Thanks
deep3lue
In terms of clarity to the naked eyes, both look similar but as for the smoothness, the right word is 'friction'. Glexible felt to have more friction as compared to Glass Guard and Glas.tR.
spellman
bought glass guard at 62.90 (epi member, ion) after read the review just.. thanks!
but, must paste home button sticker? if dint paste like hard to press as the button deep inside under the glass sp.
deep3lue
You may want to choose to get the same kind of home button sticker like mine if you find the original home button stickers too filmy. :)
Oh by the way, hope you like the Glass Guard. Any comments on it and on my review please post in here okay? It's good for me to learn to note of any possible improvements from you guys. :)
Kyubi
Nice review.. But pricy sia lol.. Can the glass guard be remove n reuse?
deep3lue
Can.. if you remove it carefully.
During my review I swapped the Glass Guard and the Glas.tR around on the same iPhone. I took the Glas.tR from my dad's iPhone and after taking out my Glass Guard and putting it aside, applied on mine, took the shots then put them back on again.
You just need to be careful and have the two phones ready side by side along with a penknife.
Kyubi
ic. . just wondering if it will turned yellowish after long use just like any normal protectors lol . . but still pondering worth or not to buy cos i guess most of us change phone every 2 yrs hahah
deep3lue
Haha.. Not convince then don't buy.. Later you buy then blame me for psychoing you! :s13:
Seriously, don't buy because it's 'good'. Only buy because you think it suits your needs and lifestyle. It's not cheap like $20 $30. So think carefully then decide.
lookers
needa wait till iphone 5S is out, by then the price can drop to $30 then can hoot =x
