Revolut
Trazora
With the cap at 10 per month, effective rebate is probably closer to 10%
dunno how you calculate, I got my full 20% for monthly fares less than $50. Topup from bank, not part of the calculation since it can be transferred out.
highsulphur
Oh I didn't know can be transfered out and have to use regardless.
Does it matter if I do the bank transfer via "connect new bank account" or "regular bank transfer"?
highsulphur
Is there any restriction on withdrawing part of the initial 100 deposit to get the rebate? Or can withdraw any amount anytime to anyone after depositing?
Trazora
can withdraw anytime to your own account. To others I not sure. Just leave some money to be deducted for simplygo.
silverbomb
for those that received the dec rebates, did it tally as 25% or it didn't?
i tried tallying but it was far off, more closer to 20% (still not accurately 20%). if it's a few cents off usually i just give or take normally.
fr33d0m
If you have transactions near the end of the month, most likely it got posted in next month. SimplyGo takes like 5 days to post a transaction.
Spikey69
Need some advice - will be travelling to Europe and USA for 1.5 months. And then to Japan or South Korea at the end of the year. Should I get the metal, premium or the metal?
Trazora
Thanks. I do have the Instarem Amaze. Why is it better than Revolut?
no fx fees, same as revolut. But can get rebate/points on the underlying card and also 1% Amaze rebate. E.g. 10x points on dbs wwmc for $2k per calendar month, citi rewards mastercard $1k per statement month, 8% for selected spend categories on maybank family and friends
Spikey69
Confirm all the experts are here! Haha. I use the Amaze instarem and it is linked to the DBS WWMC but I'm probably going to spend more than 20k for this trip. So probably have to use citibank Premier miles as a second card?
Trazora
can also use uob prvi. Now there is 4.4mpd for some categories.
wongminmin
if didn't receive the item, i applied chargeback which require up to 12 weeks . any ideas normally they take long to process?
someusername
Amaze FX rates are worse than Revolut. Cannot withdraw cash using Amaze. 1% cashback if you have metal but you need to spend a lot to break even. Depends on the use case - I use both.
