RGB LED strip $10 got sell??
Phen8210
I need it to be around <$11 as a filler for my current purchase to get exact 20% off, i am doing a search on lazada and i don't really know if it will work with the PC.. what sort of connections are normally used with LED Strips??
The motherboard is a ASRock H110M-HDS R3.0.. and i have a fsp 500w aurum gold if that helps.
EDIT: Found what i needed, Deciding between these 2
http://www.lazada.sg/50cm-rgb-remote-control-led-strip-light-30-lights-multicolor-6279175.html
http://www.lazada.sg/5m-smd-rgb-505...d-24-key-irremote-chirstmas-4720018.html?ff=1
one is 50cm one is 5meter, the 50 cm one come with the right adapter to my PSU..
