That would have been a superficial comparison between the consume grade i5/7 core chipset versus the xeon chipsets.
The major difference between Xeon chipset and the rest is the capability to have multi sockets within the same motherboard. Another is that only Xeon chipset support ECC memory which are necessary for mission critical systems. Xeon also have longer longevity compared to i7. When it comes to in-chipset cache, xeon chips are designed with more.
I guess other than those obvious differences, when it comes to durability, one can only find out if putting 2 systems one i7 and one Xeon side by side in a data centre for testing. Unfortunately I think they would be hard since we uses rack form factor in data centres and these enclosures are design rather differently from the pedestal form factor, and so for durability, everything from airflow and vibrations and so forth comes into play, but I have not really come across 1U rack server boards that will accommodate i5/i7 chipsets.
i5/i7 usually are not in the form of 1U rack but rather a workstation
acting as a server. In the past I do have such a server but later was replaced with 1U server fundamentally it isn't that reliable.
Time to time it hang unknowingly thus have to change it.
