Rig recommendation for HDTV
lechuck
Hi all,
Been 3 years since i built my own rig, now planning to get one for living room gaming. :)
TV is only a 40" 1080p display, thus no need monitor.
Budget around 1.5k
Kinda out of touch with the current tech, appreciate if i can have some advice. Thanks in advance!!
batniss
Hi all,
Budget around 1.5k
any rig with a integrated GPU (since it is only FHD) will do.
preferably i3-6xxx series and above should be extremely powerful enough.
You only need $400-$600 for it.
Having said that, iGPU can easily output 4K video.
Psycovirus
Hi all,
Budget around 1.5k
I would like to recommend ITX build for your need, maybe in a Fractal Design Node 202
c68ce827-8d52-4770-a5fd-8aa3f4512a6d
$400-600 not enough. He did mention living room gaming.
At least a GTX 1060...
MoneyFace =p
Hi all,
Budget around 1.5k
What specs is your current PC?
Chances are since your PC is just 3 years old, you just need a graphics card upgrade...
lechuck
Already given away my current specs when i moved house... haha
need to start from scratch..
lechuck
Don't really need ITX build as i can alway hide the tower beside my tv console.
Is Ryzen 5 1600x + 1070 good combo for 1080p gaming?
Psycovirus
Total damage : $1365
All quoted from PCThemes Price List
*Proposed Upgrades:
KLEVV CRAS II 3000Mhz C15 (2*8GB) 16GB White LED - $275 (Dynacore)
Cryorig C7 Cooler - $55
Psycovirus
If no need ITX, sure, it changes everything... because ITX is an added cost. However, not sure if 1070 will fit into your budget. 1600 + 1070 isn't a bad choice. Intel will be better for gaming due to higher clock...
Lets try...
Total Damage - $1665
Overshoot budget... Hmm... No HDD, No Wifi yet.
MoneyFace =p
It will be way helpful if you can provide a snapshot of your living room TV console as well as allowable dimensions for this new PC.
lechuck
Lets try...
The Mobo does not have built in wifi?
Hmm perhaps just upgrade to 500GB SSD as i don't really need lots of storage??
singupingu
Nope. Add a PCIE WIFI Adapter like TP-Link Archer T6E ($51 from Dynacore) if you needed the WIFI. 500GB SSD quite pricey though. Can consider getting online from Lazada if you want local ($216.90 for Samsung 850 EVO 2.5" SATA3)
lechuck
Psycovirus
Did quick search on Lazada
- CPU + MOBO: ASROCK X370 KILLER SLI Motherboard + AMD RYZEN 5 1600X 6-Core 3.6 GHz (4.0 GHz Turbo) - 567
- Memory: KLEVV CRAS 2 (2x8GB) DDR4 - 3000 CL 15 White LED - 260
- HDD: Samsung SSD 850EVO 500GB - 217
- GPU: Palit GeForce GTX 1070 Dual 8GB- 605
- PSU: Superflower Silver 550W - $110 [Dynacore]
- Case: Tecware F3 - $55
Total 1814 :s22::s22:
1070 should be enough, don't need TI right?
Don't need X370 for R5-1600X, a B350 mobo will do.
R5-1600X do not include a CPU cooler, so a cooler will be needed.
R5-1600 does include a stock cooler...
Encrypted11
Your chassis size getting bigger and bigger.
Getting an ITX mobo with a Miracast/WiDi supporting WiFi & BT combo chipset (in its current abomination rolled into Windows 10), building around a console-sized chassis might be ideal.
If your TV supports Wireless Display Mirroring at 1080p, decent bluetooth connectivity (paired with an XBox wireless controller etc) with proper drivers you could even use this the build as a main PC housed in a nearby room, don't have to build twice.
Assuming you aren't too far from the computer chassis (e.g. next to living room), a wireless keyboard connection should still fare reasonably well and you can avoid clogging up TV console space. Build a single regular sized PC in that case.
lechuck
yeah my TV support wireless display but not sure if it's 1080p though, will need to check.
how about audio then? can i output the audio to my soundbar through bluetooth?
Psycovirus
If you want to put your PC in another room,
there is a device called "Steam Link" that allows you to stream games on steam from your PC to the living room TV.. able to use controller to play the games.
store.steampowered.com/app/353380/Steam_Link/
Too bad, Steam Link is a US thing and being sold at USD $5. There are some imports that cost around $80~ which isn't worth it.
Are there any other solution to Steam Link?
Oh ya, the Tecware F3, $55 case is mATX case. You'll need bigger case if you buy the X370 Killer SLI whihc is ATX format.
Encrypted11
Miracast is workable, IIRC should be 30FPS 1080p. WiFi direct type connection.
BT: Simultaneously connected to small sound bar type BT speaker +XBox One Wireless controller was doable in my setup, tried before.
My WiFi chipset is Intel AC8265, wireless display is LG TV (basic 4k smart tv).
Though if you want to make something similar there are of quirks to be worked on, e.g.
-TV Miracast support/ WiFi Screen mirroring support
-Any poor antenna gain issues
-how the room is setup but a good WiFi chipset with decent drivers will give you some headstart.
There will be of course abit of latency from all the wireless connection but its reasonably within what you'll expect from wireless controllers etc. Nothing bad for casual games.
batniss
Haha always never read properly. Then again, i ise iGPU to game also.
As long not too intensive ok 1 leh
