S3 non lte firmware help!
TechNuB
ok guys i bought a 2nd hand Galaxy S3 non lte
but it was rooted.
i m trying to restore it back to its original firmware but i cant seem to find original stock firmware from m1.
any 1 with a similar experience care to share?
Jurong640
TechNuB
you can download firmwares from sammobile. All the firmware are there.
i've found the latest for you here
Hotfile.com: One click file hosting: I9300XXEMA2_I9300OLBEMA1_MM1.zip
so i assume mm1/singapore is m1 singapore? because i have downloaded and flash it using odin 1.85 but samsung kies stil says it cannot upgrade firmware for my current firmware version.
and by using odin to flash that firmware, does it mean phone is still rooted?
the SU/CWM/TA has all been removed.
device status says normal
Jurong640
yup. thats the latest firmware i've searched for you .
I9300 and under Singapore under MM1 which is M1.
You just flash it over to your S3.
Root will be gone
TechNuB
Root will be gone
ok nvm i got it....
thx bro! wish i can treat u to some cofffe =)
