S4 lock screen shortcut / Lock Screen Widgets
babyrobo
How can I set it up / activate it?
I went to Lock Screen Widgets but General Setting is blank out... :(
HUGO15481
At your lock screen, from the clock, slide down the screen...
Then you should have a "pencil" icon instead of a "padlock" icon.
babyrobo
i only got the padlock icon.. how to add other widget or apps to the screen? like iPhone has the camera function on the lock screen.. anyone?
agcken12
go to setting-> my device->lock screen-> turn shortcut on
hongge
thanks! I have the same problem as you until you share your solution.
