I had problems with keyboard disappearing (no matter which keyboard i change to, google, stock, etc) and phantom touches etc.
I am using the S View cover so I have NFC turned on. And the cover has a card holder which holds my EZ Link.
I took away the EZ Link, and the disappearing keyboard is seemingly solved! So, I tried to replicate the problem.
With the keyboard up, I put my ez link behind the my S7 Edge and the keyboard really disappears!
Wondering if the EZ Link is causing all the phantom touches etc too.
Will monitor and get back to you guys!
PS: Can someone try this too and tell me if it's just me? Thanks!
