samsung battery drives me crazy
dennis yong
just change my battery for samsung s3 but the battery is still draining at about 10% per hour without really using it. anyone know what wents wrong???
NWT1978
some background apps draining it?
try this...last time using substitute battery (even got 1 yr warranty) for S3...at first charge 2 hours ok...then subsequently charge took more than that =:p
switched off the phone...battery still keep on draining... 2 days off and battery was empty lol
thermie
check out your wakelocks... see if anything causing battery drain
mokseng
Go playstore download an app called Wakelock Detector. Check what apps are running when your screen is off. Then either change the settings of those apps or delete them.
If you're rooted, download Greenify from playstore and that will help you hibernate your apps automatically after your screen is off.
Try it out.
have installed but dun quite get it abt the function
which option should i select to have better battery life/efficiency
