Samsung Galaxy Note 10- Let's speculate...
outrun100
Can anyone recommend film SP? My original film has scratches all over, I think its time to replace. Thanks!
wensiang
If you are N10+ and not really into game, this is good. If you play a lot of games, your fingernails will leave marks on it.
https://shopee.sg/product/109581233/3923037675
trenzterra
I bought mine from here: 6👈📲tCcrcFKmT2R🎁👉淘ßao👈 https://m.tb.cn/h.48pcn46?sm=de31de【三星note10+原装菲林膜note20原厂高清软膜note20ultra保护手机膜】
Use the card they give to smooth out the bubbles and the result is quite good. Unlike those TPU protectors this one doesn't have the rainbow and orange peel effect. Fingerprint reader also works fine
outrun100
Thanks for the input. Since I also buying other stuff, so I order the PET sp from tb, really couldn't find anything like the preinstalled SP.
petricnah
There is an update, my is a local set.
Posted from PCWX using No NNPNT.
petricnah
If you can't load into bootloader mode after update, follow the steps in the video below.
mtech88
Downloading the update now
Are you downloading the German (DBT) one? Check the file size. If it is 7GB, then it is problematic. Cannot flash as the CSC is 1.2GB. Typical one is about 700MB. Use the UK (BTU) one.
PS: this is for those using ODIN to update.
Gaminator
FYI, mine's a local set, just updated to UI 3 Android 11, just a smidgen over 2.3GB. I'd thought my Note10+ would be updated in February, so this update came as a pleasant surprise.
Now. awaiting same update for my Fold 2 which is supposed to be updated about same time as the Note10+.
tkl23786
I have tried the same method.
You need either a USB-C ear-piece or connect to a computer using the USB-C cable to boot into bootloader.
I have tried using the USB-C from the charger but the phone will not boot into bootloader.
Interesting workaround.
Looks like some form of data/information/signal is needed to boot into bootloader.
