Yup, backup the data first, meanwhile using pixel 4a as my backupyou can either bring it back to samsung service centre or re-flash firmware using Odin
Most likely hardware lcd.. *#0*# is only testing the lcd touch responsive ,urs is greenish/yellowish which cant be check using this codeYup, backup the data first, meanwhile using pixel 4a as my backup![]()
That one if i m not wrong is meant for checking dead pixel or burnt mark..as some dead pixel or burnt mark need to be in a special colour then it will be easy to notice*#0*# has 3 display tests - RED, GREEN & BLUE
I thought battery lasts longer without activating the adaptive batteryWith adaptive battery, the phone last quite long. It goes into moderate performance mode automatically to use less battery.
Should be the other way if you don't use the phone much.I thought battery lasts longer without activating the adaptive battery
Have you completely dried out the phone? If not, place the phone in an air tight container of rice (grains, the uncooked type) and leave it for a few days and check on it then. The rice, as I understand it, acts as a desiccator and will absorb all the moisture. Worth a try....Not sure is it screen gone or motherboard damaged, I read Samsung SG screen replacement is almost $400, not sure mobo will be how much. Anyone got experience with outside repair shops or any recommendations for outside repair shops
Kind of odd that they overlap.does anyone know how to remove the top folder from my home screen.
can't hold it and remove it.
Read HWZ Forum Rules!
Downloading may patch for hk
You have green screen of death. Same problem common note 9. Also ganna after firmware update. Had been telling people not to update. Guess note 10 also same screen issues.Yup, backup the data first, meanwhile using pixel 4a as my backup![]()
On Tues evening, water went into my Note. Unfortunately I did not notice it immediately, I only realized when the screen suddenly blacked out & refuse to turn on, & saw water condensation on inside of front & rear camera cover.
The phone is still on, & I cannot switch off as the screen do not work. I can still hear my daily alarm ringing even today.
I suspect water ingress from the top mic hole (few months ago, was ejecting sim card tray, but insert the pin to the mic hole instead)
I have take out the sim card tray & s-pen & noticed the water condensation behind the camera is lesser but screen still won't turn on.
Exactly, I am also weary of their phones already. TBH, this is not the first time I had issues with Samsung phones.You have green screen of death. Same problem common note 9. Also ganna after firmware update. Had been telling people not to update. Guess note 10 also same screen issues.
I am wary of note 20 now. If same issue how to buy or upgrade? Updating firmware or even security run high risk of getting green screen death
thanks. updatingHi guys, local set just received an update with may security patch and some improvement
