Samsung Note 10/10+ Accessories Thread
zeblues
shopee lazada MALL- are definitely authentic
or if u want can also try UAG website but I dun think its cheaper. 11.11 shopee and lazada got promos
hope it helps :)
Got any lobang for uag frost
Sent from HUAWEI VOG-L29 using GAGT
zeblues
tried before on my ip 6+. decent for everyday usage. but definitely not the best.
good budget wise but not the best protection wise and handling not so good
if you like clear cases then go for it
if u nid more grip and like carbon fibre or tpu on ur case then maybe not
ringke fusion good ?
Sent from Galaxy Note 10+ using GAGT
xiaoheng
look around on Carousell Avg price 35+- dun get from Lazada or UAG they sell max retail price... for authentic case burlinton sq beside sim lim sq there is a shop call P2O they sell all uag... i bought for yrs...
TingYao
Then u will have to find out does the $28 one charge from 0% to 100% in under 47mins on the Note 10+
Looking for charger too... Any idea how it compares with the baseus EU-910? :s11:
It costs less about $28.
fOreveRity
I have a one day old uag plasma ice for note 10+ letting go at 30. Not used to the bulk size else a great case. Dm me if interested
Sent from Samsung SM-N975F using GAGT
ApexMan
Any case with same form as the Samsung led case
I'm looking for a slim fit type for the note 10 plus
Preferable the 4 corner edge is rounded curved
earthtk
I wanna recommend this TG which I posted previously.
Previously I tried I think I did a bad application. Even so after 1 month the fingerprint still works and still fits very well with my Spigen ultra hybrid. I reapplied another piece, perfect fitting!
https://m.tb.cn/h.etFodfF?sm=5c38cd
Sent from Samsung SM-N970F using GAGT
earthtk
has anyone here pasted protector for the back of your phone?
I did. Using a Spigen ultra hybrid but I find over time, dust and stuff can get caught in between the phone and the case.
I use those cheap carbon fiber designed one I pasted at the back of the phone for a cleaner look.
kitoshizc
so far anyone manged to buy one more original 25W charger from Samsung? It's kinda troublesome now. Need to buy some usb c cables and buy another 25W charger plus car charger with Power Delivery capability.
