Samsung Note 7 vs S7 Edge Screen
chaddeus
Since I got a S7 Edge (second), I just notice a slight difference between the screen color on the Note 7 and S7 Edge.
The Note 7 seems to be more WHITE while the S7 Edge more blue-ish. Note sure if my S7 is the problem or that is just how it is,
Anyone can do a slight comparison?
Click link below to see the photo
Psycovirus
It is just software control. Go to Settings -> Display -> Screen Mode and play around to reduce blueness...
chaddeus
They are both set to Adaptive Display. Even if I change to other mode, and play around with brightness, the S7 Edge seems to be more blue-ish
SUrely someone here has the Note 7 and S7 Edge that can compare and feedback the result
- Charles
Intrinion
Senior Moderator
Senior Moderator
Some displays are in general warmer while others are towards the cool end of the temperature spectrum.
This is due to differences in manufacturers, production batches and sometimes are even calibrated as such.
Wouldn't worry too much about it!
Unless it's exceptionally cool (maybe you could possibly take a photo and show it to us over here?)
Cheers
chaddeus
Cheers
So what do you think? I dont think I will notice it if I don't compare side by side
- Charles
Teo Ming Ern
Making these screens are not an exact science despite many advances... so there will be differences in the brightness and colour of the screen.
Sidler
I have the same experience.
I changed S7Edge to AMOLED Photos. it's a little warmer, but still not as warm at N7.
N7 screen is still nicer, better colours at similar brightness.
Stopped using N7 for a few days and I don't notice it anymore.
crntbs
copied from tech radar
"Exclusive to the Galaxy Note 7 is Mobile HDR, which shows brighter colors and deeper blacks, according to Samsung."
