Samsung S3 LTE Charging Issues
binbinbong
Hi guys,
Recently when I charge my phone at maybe 5% for half an hr it still show battery charging and didn't increase I need to plug in and out the connector after awhile it start charging again.
Is it my battery spolit or the charging head of the handset got issues.
pker88
just bring your phone and charger cum cable to sammy at PS or Marina sqa then they will replace for u on the spot
so easy as they got ample stock
binbinbong
cable problem? not the battery or the phone itself the connector head?
replacing with Sammy? I brought my handset around dec 2012
pker88
If only if its 6 months then can.
yea mostly is before 6mths is will affected
so just go RMA it and it will be fix
,my friend s3 3g kanan it pretty fast
same for my s3 lte
so we just go RMA and get replace on the spot
good service !! from samsung :D
if over 6mths then just go outside hoot a OEM samsung charger cum cable is not exp actually plus u can use on others phone or use at work place as charge
binbinbong
thumbs up for Samsung! went down service centre and got the cable exchange, but still monitoring if the issue resolved
pker88
its the charger usualy
check if your it veitnam or china
china then u r safe
I demand to change both charger & cablea
and now im damm Happy
Ev0d3vil
china then u r safe
Beg to differ though.. The cable I change Liao so far so good.
