SD card help!
Masa27
Anyone can recommend any method to retrieve photos & videos in I supposed damaged SD card?
SD card was fine during overseas, but after coming back unable to detect.
yusoffb01
What microsd brand you used? Is it legit? Or you bought a cheap one with fake capacity?
Masa27
Sony SD card. Tried using different card readers but to no avail. Any place where I can send my sd card to retrieve the photos and video?
K202020K
K202020K
jq75
maybe must use sony sd card reader?
keenklee
Maybe the contacts dirty. Use an eraser and gently clean it and try again.
My frequently used microSDs are like that but I use a different method to clean.
HTH.
Masa27
Ok will try the methods suggested. I have already tried using different computers and laptop as well.
Thanks all!
Masa27
Just googled Sony SD card warranty only 5 yrs. quite sure mine is more than 5 yrs since 16GB only.
wwenze
Warranty seldom covers data recovery, unless mentioned upfront like when you buy Seagate and WD HDD.
Cleaning contacts is first thing to try. Next is to use aircon to blow at it for a while then you insert it into the card reader. Next is to use hair dryer to blow at it for a while then you insert it into the card reader.
