(SD) MicroSD benchmarks!
xtramadness
Can give recommendation for 64gb microsd or sdcard to be used for Samsung NX300M camera? Am currently using Samsung Pro 64gb.
There's not much reason that you might want to move unless u just want to change brand?
Pro is quite good and changing a card (of same or a little higher tier) may just give you negligible speed changes considering pro is one of the higher tier already.
shadow84
Would like to buy additional 64gb microsd and will still use back the Pro 64gb.
xtramadness
Review: PNY Elite 128GB MicroSDXC Card
Today, we have another of PNY’s microSD card available for testing, full thanks to Jonathan for loaning us his new card for testing. In today’s benchmark, we will be pitting up its Elite edition of the 128GB variant of the card. As noted in past tests, the 128GB and 200GB microSD card’s performance is totally different compared with its lower capacity of the 64GB card, so this is a mark of performance of the 128GB variant and not the whole PNY Elite series!
In conclusion:
Overall, the speed whilst does read up to 80MB/s for most part of the time, overall, it is mostly below that. Furthermore, the speed has been rather inconstant especially in the write. Looking at the random speed, however, like most of the other 128GB’s, this is definitely going to be a throttle on mobile devices. Hence again, we do strongly advise against using this in mobile devices. With pricing around less than $50, and a lifetime warranty, however, this is good enough for budget hunters.
Read the whole review here!
Koenig168
Most 128GB cards have quite low write speeds. For the price, it is a decent enough card.
xtramadness
And hence the last sentence
I would say though, get the 200gb sandisk ultra over any 128gb's if possible. :)
I wonder, though, how does the 256GB and 128GB EVO Select perform.
Koenig168
I had two of the 200GB Sandisk Ultras. :) Performance is similar to the 128GB variant. Sold one because I wanted to get the 256GB Samsung Evo+, then when it finally came out and I saw the price tag :s22::s22::s22:
xtramadness
Not really it has better burst speed for moderate files.
But u ish rich... Evo+ and Evo Select aint cheap
Koenig168
I'm a poor man. No way I am going to cough up USD200 for a microSD card. I'll wait for it to drop to a more sane level.
enriqueyang
has anyone tested the remax 128gb microsd?, can it support 4k well, and can it handle "tourture" such as alot of photos n 4k
xtramadness
No point getting REMAX if you ask me. Just get SanDisk/Samsung (yes even samsung's better) or if u have the budget, Lexar.Strontium not bad choice too.
Koenig168
^^^ this.
No comment on Strontium but I am using mainly Sandisk with good results and a couple from Samsung, Lexar and Sony.
xtramadness
Sony doesnt have the best performance, but so far so good as well. SanDisk/Samsung are quite competitively priced as well, if you know where to find :)
Koenig168
Now waiting patiently for Samsung Evo+ 256GB to drop to a reasonable price. :)
