Seagate 4TB external HDD strange problem
kobolds
I had been using my Seagate Backup Plus 4TB USB 3.0 Desktop External Hard Drive for about 3 years (which is almost 90% full).
last week suddenly become unrecognized. from win10 disk management , I can see the hard drive but what suppose to be 1 (4tb) partition become 2 partitions raw.
using testdisk, I'm able to access the drive and copy out all the files without any error or corruption .
after copy out all files, I decide to delete partitions and format.
1. using win10 disk management
first I delete the 2 partitions then convert to gpt . no problem but when I quick format ntfs . it took very long then show fail. and the hdd disappear from disk management . I unplug the usb and re-plug in . it took more 5 minutes for the HDD appear in disk management. I retry format same result.
Next , I try devide into 2 partitions and format. same result failed.
2. using seagate discwizard
I try to create MBR advanced format . 1 partitions (4tb) created but when I format same result failed.
last I going back to disk management. this time I convert it back to MBR which created 2 partition (2TB and 1.6TB) only 2TB can be use. I do quick format and finish OK very fast .
I unplug and plug in the usb , my win10 very fast detect the HDD unlike when i create 4tb partition.
I did slow format on the 2TB partitions which took almost 5 hours. no error , no bad sector.
I had tried take out the HDD and put in other external HDD case, same issues problem .
I'm loss. I not sure whether the HDD is damage or not . There's no weird sound when boot and since no corruption on all files copy out , I assume the HDD is still working fine. if that case why when create 4tb partition is OK but when format failed?
any suggestion ?
jtjt00
Download HDTune and do the following:
1. check the Health tab of your seagate drive
2. run Error check (do not click Quick scan)
yusoffb01
time to buy new one. too many bad sectors so cannot complete format
