Seasonic Full modular cables compatible with each other?
tremor
Hello sexperts.
I currently have a Seasonic X-660, but i think going to spoil soon, now there is a long lag between pressing power button and PC actually powering up.
I'm looking at the Seasonic Focus GX series. I am lazy to change all the cables, some more already routed.
Are the 2 models' cables interchangeable with each other? So that I can just replace the main unit itself. Don't touch the cabling inside.
ystoh133
tbh, I've never recommended people using the same old PSU cable even if they're sold under the same brand.
First, pretty sure if your old cable short out your new PSU, warranty will be voided.
Second, you won't know if it's your current psu / the cables that are at fault.
Just replace it with the new one, ain't nothing bad bout everything being brand new. Take this chance to better reroute everything also.
Besaid
I second ystoh133's comment.
If you die die insist, best is to email Seasonic Customer Service and ask.
Not worth risking your entire setup based on some stranger's recommendation in the forums, right?
hafiz116
Agree 110%. If you are replacing the power supply you can take it as an exercise to clean dust buildup too which will hinder you in the future :s12:
lucied
Suspended
The pins on the cables might be arranged differently so it is at your own risk.
I reused the cables from my x series when I changed to platinum series. No problems encountered.
SkyShroud
as long the "lock" positioning is the same, it should be compatible
if the "lock" positioning differ, you can't insert fully in
Antisocial
That guarantees nothing when there is no unified electrical standard on the PSU end for modular cables. Don't do it.
Also if OP wanna save $60+ just get the Cooler Master MWE Gold 550W on Lazada for $100 instead of Seasonic. 550W is already overkill for his current rig.
SkyShroud
yes, there isn't
however, for manufacturer within themselves, they tend to set a standard for itself to reduce to unnecessary need to manufacture different type of cables, for the sake of reducing cost and not create unnecessary inventory mess
it is actually quite easy to google the cable compatibility out from 3rd party cable maker, if 3rd party cable pack can work for numerous models and if these 2 models are within that list, it means the pin out is the same.
like
https://cablemod.com/compatibility/
and
http://www.powerhousepc.com.au/seas...odels-of-seasonic-power-supply-full-pack.html
tremor
I actually took the jump and bought the seasonic focus GX-750. $145 after discount and using coins on shopee.
Only 2 cables not compatible, had to swap the out.
CPU and PCIE cable need to change. Motherboard and other peripherals cables are the same. I prefer the old cables as they are fully sleeved, the new cables are flat type.
