Seeking advice on building custom desktop
contagious
Hello there,
I'm new to PC building and hope gurus can help with input on building a new custom desktop.
My budget is ~$1000 monitor+cpu only.
Don't really need a very big monitor so maybe can cut some monitor $ into cpu .
Main usage would be gaming/streaming on twitch.
Could anyone provide me a breakdown of the items and prices?
I'm looking at nvidia cards though, not amd ones.
TIA ! :):)
m3 th3 last
Hello there,
TIA ! :):)
Hi there, what kinda of game u looking to play and at what setting? Med or at the best details.
What kinda of size for ur monitor also.
royfrosty
Asrock b75m dgs + i5-3350p ~$271
Crucial 8gb 1600mhz~ $89
WD blue 1tb ~ $77
Leadtek gtx650ti boost 2gb ~ $201
Cm311 + fsp hexa 500w ~ $105
Windows 7 home ~ $115
Dell s2240l ~ $199
Total $1057. Buy at tradepac. Diy
contagious
Hey there, looking for 19-21" monitor. 23 too big..
Hoping to play at max settings. :o
jiaweiii
Hello there,
TIA ! :):)
Are you maine :o ?!
contagious
WD blue 1tb ~ $77
Dell s2240l ~ $199
any other input besides this one~ ?
I've got a spare windows 7 home premium somewhere so i think could save some money from there also :o
jiaweiii
since you got spare home preium i think you can get msi b85 g43 and also i5 4570 top up abit more
contagious
Trying to keep within the 1000$ budget tbh =x
Not sure which would be better ;_;
Jian19
i5-3350p + Asrock b75m dgs ~ $271
Crucial 8gb ddr3 ~ $90
Wd blue 1tb ~ $78
PC 7870 ~ $241
Superflower hx 500 ~ $89
CM n200 ~ $52
Dell s2240l ~ $199
$1020 buy and DIY @ tradepac ask for discount...also check ur window is 32 or 64 bit...32 bit only support 4gb ram ~
Optional ~ Samsung oem drive @ $21
royfrosty
If OS is not needed and you really need to keep within 1k.
Asrock B75M DGS + i5-3350P ~ $271
Crucial 8gb 1600mhz ~ $89
Toshiba 500gb ~ $60
Powercolor 7870 ghz edition 2gb ~ $241
CM 311 + FSP Hexa 500w ~ $105
Dell S2340L ~ $219
Total ~ $985 Buy at tradepac. DIY
contagious
psps keep forgetting to say that i prefer nvidia card after my sis's amd one spoilt ~1year from buying.
Yes OS is 64bit. :D
MoneyFace =p
Hello there,
TIA ! :):)
CPU+MB: Intel Core i5-3470 + ASRock B75M-DGS @ $292
RAM: ADATA Premier DDR3-1600 CL11 4GB @ $43
GPU: Leadtek GTX 650 Ti 1GB @ $164
SSD: Plextor M5S 128GB @ $127
HDD: Western Digital Blue 500GB @ $64
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
CASE+PSU: Cooler Master Elite 311 + FSP Hexa 500W [80 Plus] @ $105
DSP: Dell S2240L 21.5" LED [e-IPS] @ $199
Total: $1015
Optional:
RAM: ADATA Premier DDR3-1600 CL11 4GB X2 @ $86
DSP: Philips 200V4LSB 19.5" LED [TN] @ $149
Only if you still find 21.5" too wide and doesn't require eIPS.
Not recommended as you are sacrificing screen image quality.
Reference prices from SLS.
Kindly request GS (Nigel) or Fortran (Ivan) for possibility of price-matching against SLS.
produde1999
:3 if you really want the best value
I would recommend just get cheaper amd processor fx 6300 will do great for league of legends.
And use the money left can buy better graphics card or solid state drive or keep it
I would recommend getting solid state drive @@ It cost $140 more but worth it. It not only improve performance, but also secure ur data better and more durable, and faster gaming response
