As above, if my ceiling light de wiring is surface trunking, how to install new LED light fixture ?
I saw a couple of the display set, baseplate no hole, no folding nor breakaway tab for wire ingress, should I cut or drill hole then put rubber gasket or sealant on the sharp edge?
Some is the diffuser cover over the baseplate and flush with ceiling too, so those are goner right?
Anyone have any experience with this?
