[SIC] Realtek Driver to add SRS, Dolby Digital Audio & DTS!!
BlackWing1977
I experience the same problem.
Was fine after installation, then after next boot, no more sound.
I launch realtek audio manger, fooled around with the default device setting and then it started working again. I'll see if this problem continues tmr.
For some reasons, the default device setting, seems to reset it...
I get no sound after playing one round in BF3..... so I got to exit and change setting... anyway, I am currently using ZxR, no such problem liao... :s13:
NY__chickenpie
u have to extract the activator.7z and run the bat file. it has the extension of 7z, use 7-zip to extract it
ducky_88
Source @ Gamespirit: Realtek mod@X-FI
It was modded by a Spanish guy, he previously even did a Creative Mod with CMSS and Crystalizer.
I tried the driver, and it made movie sound like the whole Cinema experience with my on-board sound Realtek ALC889.
Download location @ https://skydrive.live.com/?cid=6D9572C7052312C2&id=6D9572C7052312C2!218
I am using the latest 2013 version. But for some reason, I can only choose the default CD or DVD format, I cannot change the default format to 24bit, 192khz which I used to do with the normal driver. Anyway, with SRS, DD and DTS turned on, it sounds great. :D
Try it out and report back here.
which is e download file to install? so many. :s22:
