Sigh... My pc gave me problem
jq75
power on as per norm, 10mins of use, suddenly, abrupt shutdown
tried to power on, casing light blinks for a second or two and then thats it.
troubleshooting tt i have done..
1. swap psu / power cord
2. power on via mb switch
3. remove all rams,drives disconnected, bare system with cpu
4. clear cmos jumper and remove battery
all the above, but there's no change in the 1-2 sec boot up and died syndrome..
can't even go into bios or see anything on monitor, the 1-2 sec boot is way too fast..
what can i do? my ultimatium is MB died..
jayz89
Most likely mobo uplorry le
If u change mobo, just live chat with microsoft and provide the cd key then ok liao
I recently just did that after changing my whole rig
Firegear
I have a trick can help you revive your motherboard temporarily. Remove everything and re- Assemble do not connect to power supply for 3 day and also remove your cmos battery from motherboard no need to put back liao.
You know why I know. Refer to the link below
http://forums.hardwarezone.com.sg/hardware-clinic-2/pc-wont-boot-fans-spin-up-brief-moment-then-quit-5514715.html
Sent from Samsung SM-N910G using GAGT
jq75
No batt and boot up from there? Why is it a temp measure?
Firegear
Your motherboard probably don't have short circuit protection, as what I researched mostly MSI and asrock mainboard don't have. that why will happened like this. Short circuit is cause desktop casing discharge to motherboard, make spoiled the BIOS chip, once if this issue there is 50/50% chance of recovery liao. If you use the method above I posted, if not Neither you change casing or or you find the root problem. If not your next motherboard you replace in soon will have same problem.
If you motherboard have warranty please rma immediately.
This tips was given to me by a special service center.
yusoffb01
a quick question, if i replace with a new board, do i need to reformat my hdd C:?
on win 7 pro..:(
If same chipset don't need. I have changed from h67 to h61 after I hibernate windows
jq75
in my tech specs its a ASUS P8Z68-V:(
jq75
i'm considering, bring to sls for last attempt troubleshooting. cos if confirmed dead, can get new parts there and replace it:o
no point go back to asus since its out of warranty
Xtremedrake
Might want to try changing cmos battery. Some mobo won't boot if the cmos batt is dead. (read online, for my case it wasn't the batt) But if that doesn't work then probably the bios chip up lorry maybe?
peterchan75
Try remove the hard disk and boot to BIOS. See if it stays there. If it does, then boot with 1 RAM modules. The main suspect is either the RAM or the hard disk. Mobo should be the lost suspect.
jq75
I tried to boot w board and cpu only , it didn't boot for more than 2sec.
Just a quick spin of cpu fan and it's dead again
undead102
Fan spin then off. Only with cpu and motherboard no ram. If motherboard is working the fan should be spinning and spinning. If spin then off high probability that the motherboard is faulty. Cannot be psu as you said that you have change psu also same thing happen.
jq75
will try do own troubleshooting again for another day before sending down to SLS..
earlier tried a few combinations.. same result, hdd pulled to connect to another pc, still works fine, docu and stuff all intact..
will try with basic bare troubleshooting to conclude the possibilities, i swap the sata cables also while testing it out, but still not much hope
jq75
i think i shld conclude the mb is unstable or rather dead already.
using power switch on the bottom of mb to power up with the few combinations
1.board with cpu, no ram
2.board with cpu, 1 stick
3.board with cpu, 4 sticks of ram
4.board with all sata drives connected
cpu fan spin and stop, tt's it..
if a normal working board, no ram or whatsoever there shld be beeps, but this time no beeps at all.. cleared cmos with jumper and battery removal, same outcome..:s47::angel:
jq75
can't reach bios screen..
jq75
is it worthwhile to repair mb these days?
