Simba very difficult to create HOTSPOT although can. Got EIGHT senior, no?Thinking to downgrade from eight to simba $5 plan, diff of $3/mth
$36 a year, $360 a decade
My mum doesn't use her phone in the mrt, also using wifi at home
so how is simba network reception in the open?
What the difficulty?Simba very difficult to create HOTSPOT although can.
To be honest, eight 4G $8 to Simba 4G/5G $5 is an upgrade, not downgrade.Thinking to downgrade from eight to simba $5 plan, diff of $3/mth
check coverage before u sign upThinking to downgrade from eight to simba $5 plan, diff of $3/mth
I using Simba with Xiaomi phone. Hotspot with my phone to iPad is seamless leh. Worth it for the cost/monthSimba very difficult to create HOTSPOT although can. Got EIGHT senior, no?
Have used eight 4G and Simba 4G/5G NSA before. Tried eight 4G for a few months and i find myself with frequent no network or emergency calls only, i don't experience these type of issues of Simba.
On eight, you get the lowest priority on Starhub weak and congested 4G network.
On Simba, you get the same priority on Simba's own network.
I created hotspots with SIMBA multiple times. Don't see any difficulties?Simba very difficult to create HOTSPOT although can. Got EIGHT senior, no?
