Singnet Fibre Optic Broadband Speed Discussion
Jamesykl
Hi James, as requested. Busy with work lately, this time uses another PC to try with 1.5m cable direct to giga port.
San Jose is real pain to past through highest speed as below
Just out of curiosity, how do you run the cable to your pc? You ask Singnet engineer to do it or all by yourself?
yodajedi01
I'm not sure why i'm not getting my high speed.
i'm getting less than 100Mbp in SG.
I'll test again tonight.
if not will call up singnet again for an answers ....:s16:
Jamesykl
Wireless connection will definitely be slower than cabled connection. Check whether your configuration.
yodajedi01
yes, but even on direct connection?!!!!
I'm surprise.
now beside the speed issue,
i need to figure out how to reconfig my Synology NAS to for a DDNS storage.
(not sure if it that ppoe need to be set)
AC2
it could be your gigabit network adapter also. I was using the build-in gigabit adapter from gigabyte motherboard and i only manage to get 33-60 Mb/s download 89-95Mb/s upload on the singnet utilities website. However, I can reach 93-98 Mb/s download 113 Mb/s upload on Speedtest.net website.
Then I went to install a TP-link gigabit adapter on the PCI slot on the motherboard and I am able to get 135 Mb/s download and 98 Mb/s upload on speedtest.net(sg server)
I remember the singtel guy's laptop can hit 198 Mb/s download 94 Mb/s upload on my fibre. But I cant get that on my System... Not sure what went wrong
-Cable used is Cat 6 btw
Tried a few times back to back. result is the same.
yodajedi01
I remember the singtel guy's laptop can hit 198 Mb/s download 94 Mb/s upload on my fibre. But I can get that on my System... Not sure what went wrong
Lol
weird, my test both singnet utilities & Speedtest gave me almost the same result
Really less than 50+++
both macmini and my Asus eeePC 100HA. Both have Gigabit lan port.
Both lan and wireless.
Best is use Cat6 but on a normal Cat5 cable, i don't think it's that REALLY BAD
AC2
could it be because or proxy issue? I am not using any. Does it help to increase speedtest.net connection speed? Maybe the engineer's laptop are using proxy that why so high?
Jamesykl
Yes all work was done by Singtel cable & trunking no extra charge.
Just had my Singnet fibre optic connection hooked up. Trunking to study room done by cabling guy accompanied with group of Singnet engineers armed with laptop to do speedtest. Here's my speedtest:
yodajedi01
I thnk i Know what is wrong with my speed being slow.
Possible reason is my ONT & RG is in my Hall.
More of my Gargets are in my room.
So the best way to go about it is useing HomePlug HL280E.
test for the speed, i believe it could be due to Old wiring.
Oo well maybe some other time, I may ask them to place another Point in my room
Jamesykl
You need to use Cat6 or Cat5e wiring from the 2Wire to your pc to achieve the fibre speed. If you are running wireless, you can only achieve a maximum of 70 Mbps. The Singnet engineer do trunking to your room free of charge. If you do on your own, buy a Cat6 cable (best) that can run from the 2Wire to your room but its going to be expensive. A Cat5e is equally good.
coolstardy
Will the speed drop when mio tv is played? Btw r we supposed to be getting any free 2 mths trial thingy? I just signed up for the exstream
Homesports
yodajedi01
Homesports
If you sign up during the roadshow @ PS.
you get 2 months FREE not 2 mths trial.
