skin care help
acneoilyskin90
Hi,
I have oily and acne skin... i'm very sad and seeking for help...
any products or clinic, anyone can recommend??
I tried seeking for review... gangnam laser clinic sounds like a good place...
any one has any clinic to recommend??
changyenub
Hmm maybe you can go to Beautech at Novena! I've been there before and they do a good analysis of your skin. Mine has improved alot!
qsqs123
To be honest, if you don't mind taking medication, isotretinoin is your best bet. However, it requires doctor's prescription. Please don't get it from outside sources or on your own. It comes with certain side effects like dry skin, dry lips and requires monitoring.
Go to dermatologists at hospitals or NSC would be better than clinics imo
tlkchew
Hi,
Hi You should try this soap / body wash from Kikikoorganics.com . they have sericin collagen extract that help with acne. i suggest trying the cocobath with sericin (homme)
so far several people use have seen improvement.
tlkchew
I'm using Cetaphil. Very light cleanser but clean. Sometimes less is more
problem with cetaphil is that it still has Sodium laureth sulphate. to help with allergies and skin irritation, this is not good. should use only natural ingredients.
acneoilyskin90
Is it expensive??
I don’t dare to use products... my outbreak are due to the use of wrong products!!!:(
