Slow Hard drive = FPS stuttering?
MercuryRyan
Hi, as the title states, I'm just trying to find the cause of my insane fps stuttering in multiple games.
So I'm using a Lenovo Y700-15ISK, specs are as listed:
Intel I7-6700HQ 2.6GHz
8GB RAM
GTX 960M 4GB
5400 RPM Hard drive
I know my gpu itself isn't strong at all, especially compared to the new 1050 ti or 1060, but I've seen decent fps at pretty decent quality settings by youtubers and benchmarks with the only factor being different is the ram and hard drive.
So a few examples of this stuttering:
GTA V - Lowest settings to Med settings at 1080p, average 40 - 60 fps? But it struggles to keep it at that number especially when driving, it has dropped many times when cruising at a smooth 90 to 1 fps and just hanging there for like 10 seconds.
Overwatch - High to Ultra setting at 1080p, average 70 fps. Occasionally, like every few days or so, it just goes crazy and the same issue as GTA happens throughout the day even after turning off my pc and leaving it for like a few hours before coming back and trying again.
Player Unknown Battlegrounds - Lowest Preset with High textures at 1080p, average 50fps, buildings take ridiculously amount of time to load and random invisible barriers appear until the buildings fully load. Loading into each match takes a really long time as well. It will usually be extremely stuttery until the game has gone on for like a good 5 - 10 minutes or so after the buildings have loaded.
The stuttering isn't like 50 to 30 or 20 fps, it just drops to 1 fps immediately and will usually make my pc hang for like 3 - 5 seconds, sometimes longer.
I've actually been planning to add an ssd to this pc and move the OS and some of my games over but I don't know exactly how much of an impact it will have on my gaming experience.
TBH, i would save up for a decent desktop, but given my current circumstances as a student, it would be kinda impossible and i more or less will have just enough to get a 256 gb ssd.
(Side question: If I moved only the OS over to an SSD and left my games on my potato hard drive, will the games still have bad performance like this or will the fps stuttering improve?)
I don't really care that much about graphical settings, I just need my FPS to stay consistent throughout without the screen tearing.
Also, I have already tried playing around with the different settings (different resolutions, different presets, custom presets, etc) on all my games, it really does nothing to help with this issue.
In esports titles like overwatch, the game runs fine most of the time, so its fairly bearable, but for games like GTA V or assassin's creed, once the stuttering starts, its just impossible to play.
watzup_ken
I think there may be other reasons for the FPS drop. Hard disk don't affect FPS, but only affect load times. Do you experience sluggishness overall besides gaming? If it is sluggish overall, then it may be signs of a failing hard drive.
86technie
Your findings is the same with Notebookcheck.
https://www.notebookcheck.net/NVIDIA-GeForce-GTX-960M.138006.0.html
If you are hardcore gamer, should have just get a desktop not
a notebook.
Performance on a notebook is definitely inferior to desktop since
notebook components are optimized for power savings and low wattage.
For now either you can just:
- Do a clean install of Windows 10 since it will take few hours
and it should be installed with drivers and etc.
- Lower the resolution of the games you play.
If you change it to SSD, as above it only helps with speeding up
the application and loading not really helps the frame rate.
I have even test with a 7200rpm HDD, this despite it is faster
than 5400 rpm but it may make the notebook more hot.
That is why manufacturer don't include 7200rpm in the first place.
SDD will bring up the cost even further.
For me I am trying to speed up a old notebook with a rather weak CPU.
That is why I tried both 7200rpm and SSD but both have pros and cons.
For game application it is best to be on either the SSD or HDD that you install instead of second hard disk.
SSD is not cheap either way thus if you want to try 7200rpm HDD.
Just remember to get a notebook cooler.
Hope this helps.
eric3743
Some of the suggestions.
You can increase the RAM as it is low.
How much depend on Intel, link;
https://ark.intel.com/products/88967/Intel-Core-i7-6700HQ-Processor-6M-Cache-up-to-3_50-GHz
SSD is recommended as above.
If online games, then monitor ur connection as many complain on lag.
:D
Sent from Seven Enlightenment using GAGT
watzup_ken
What do you mean by sluggish overall?
I mean do you experience slowness overall besides in games? It is not natural for FPS to fluctuate wildly to 1FPS. Do also check the temps and if the fans are working.
sandyph
Yeah having same problem with msi gp62 (i7 6700, 960m)
I notice that it will get more sluggish as the temp goes up and also when there are a lot of sounds (especially in PUBG, it will run fine then you hear a gunshoot far away and the frame rate drop to below 10)
Still trying to pinpoint the issue
Sent from Samsung SM-G930F using GAGT
