Small stylus for iPhone
everex
Hi all,
Has anyone purchased or used a short stylus that works with iPhone? I have seen many stylus in Lzd/Shpee, but all of them are mentioned works with iPad or android devices, nothing specifically for iPhones.
Even better if there is an iPhone case that can accommodate hiding a short stylus. I like iPhone, and also want stylus functionality.
Thanks in advance. 😊🙏🏻
Jirachi
Drawing sketches, signing docs, still better with stylus. Not everyone’s use case.
You try and let me know how the stylus works with iPhone. I tried before with Apple Pencil and the iPhone screen just won’t pick up any inputs.
reddevil0728
Which is why I think TS is asking for recommendations ma.
everex
Those capacitive stylus that looks similar to Apple pencil but costs less than $20 work ok with iPhone. But they are too long, am looking for a shorter version. I’m not sure if the Moto stylus works well with iPhone. I understand Samsung S pen will not, but I haven’t tried this yet.
everex
Can try those rubber tip kind. But will never be as effective.
you do that a lot?
Yes I have that, but not good for sketching as the rubber is too big for detailed drawing.
I would say not a lot, but just good to have it.
Actually, would be great for 3rd party accessory sellers to come up with a case for iPhone that comes with an embedded short stylus. So the iPhone becomes an “ultra”. 😊
froztheart
Then Apple will tell you to head over to Samsung instead. :ROFLMAO:
Jokes aside, those cheap cheap 3rd party ones, have you tried them?
reddevil0728
this is an alternative. might be "better" because you can see through the clear piece. but also more prone to missing or damaged hence got the cap
but if you think about it, it may not be demand hence they don't.
Why would Apple ask customers to do that? 🤣
ya lor. they will say if you want to draw get an ipad with pencil
froztheart
Yes, since there's iPad for users that is looking for such purpose.
But for OP, that is looking for iPhone size but with stylus, not applicable. hahahaha
