Small TV with DVB tuner
super365
Do you all think 32 inch too big and bulky for a hdb common bedroom? Thinking maybe a 24 inch will do.
Intend to wall mount below window, can put but seems tv area is big, not sure will make room too crowded/stuffy, like too many things. Most likely sit about 1.5 to 2 meters away.
But I also thought if I want to use 24 inch tv surf internet the text might be too small if sit about 1.5 to 2 meters away.
super365
I saw 32" philips 4002 with 32" lg 550 side by side. The display wordings can see a big differences. Although yes, lg is a about 100 more. Even so, philips 5102 n 4002, i see differences as well. 5102 n 4002 not same panel? Anybody has a 4002 hooked on to ps4? Can comment in picture? Actually I dun need any smart function. But display kind of turn me off. N yes, BD at 229.
I agree 5102 is much clearer than 4002. 5102 more expensive $120 than 4002, people interested can compare these 2 at vivo best denki. I think is the 5102 pixel plus thing make it nicer. Compare same brand, tv is like the more you pay the clearer it gets, really got quality difference even same size and pixels. Even if same size different brand, expensive one also look better.
Medicated Oil
High Honorary Member
Gov issued box.... i think the antenna worth $29
if deliver & install, need at least 3 weeks to be able find time slot.
eligible-households-can-redeem-a-free-antenna-and-set-top-box--which-will-come-with-a-universal-remote-control-2.jpg
Courts selling DRACO $100+
thanks for letting us know.
Thank you for sharing the above information.
Seems like the Draco tv box and funke antenna is the better option if you can install and tune by yourself.
The store can play punk by saying that only one antenna is stated on the voucher.
Sorry, I just saw the ssss.
wongminmin
Actually no, i got the 32"tv idea in bedroom from my friend.. Some people even bought 55" tv for bedroom. :s13:
24" viewing distance suitable for 0.5~1m
32" viewing distance suitable for 1.5 to 2m
i tried using 32" for 0.5~1m, it will stress our eyes.
super365
32" cannot sit 0.5~1m? Too close, eye move too much? I thought many people buy 32 PC inch monitor and ok with it put on table and sit chair less than 1m away from monitor, type keyboard on table. Table depth seldom got more than 1m.
PC moitor inch and TV monitor inch same thing measure diagonal inch correct? Last time I always see my 20" lcd tv more square looking shape looks bigger than dell u2311h 23 inch rectangle shape.
wongminmin
i mean 32"tv :s13:
From my own experience...eyes very stressful if want to sit so close, tv vs. monitor
-generate more heat
-lower dpi
-brighter
those people buy 32" monitor for gaming/multi-tasking/applications purposes.
24"monitor is enough for normal pc user.
super365
i mean 32"tv :s13:
-generate more heat
-lower dpi
-brighter
Just to clarify my understanding, 32" pc monitor is can sit close about less than 1m, 32" tv cannot sit close less than 1m because will stress eyes, is that correct?
Is 24 tv vs 24 pc monitor also similar logic like 32" above?
Never have 32" before so I don't know.
Ed.YEO
Do you all think 32 inch too big and bulky for a hdb common bedroom? Thinking maybe a 24 inch will do...
自從49寸大機佔佐我客廳32寸機“地位”之後。。。32寸機就“移位”佢房間。電視擺位離開我枕頭差唔多1.2米,如果用番客廳畫像設定,就會造成眼睛唔舒服狀況。背光必需調低,亮度必須調低,反差必須調低。
wongminmin
u try loh...
i don't like give definite answer, because different people different perspective.
i did read article somewhere, TV are make brighter so they can be view at longer distance.
u see this guy 55" in bedroom. :D
Previous photo. I made a mistake here. Should not use RGB bias lighting, very unprofessional. Quickly ordered 6500k led strip
dk why upload my image became blur but ya
super365
bei guang is the light behind the tv?
32" brightness and contrast you adjust lower then at 1.2m distance away you watch the screen feel ok for eyes already?
adjust lower does the image display still look good?
If 32" at normal settings, what minimum distance do you feel good normal for eyes?
Ed.YEO
32" brightness and contrast you adjust lower then at 1.2m distance away you watch the screen feel ok for eyes already?...
背光 就係BackLight。
背光直接影響亮度,對比度。所以背光一調低,對比度,亮度就可以調低啦。
不過,各人調整情況唔同。因爲我房間好少開燈,所以背光就有得調低至50%。
如果你房間睇電視時間都係於關燈狀態,咁。。。背光就可以調低啦。但係如果系相反嘅,你都係開燈睇電視,直到睡去,咁背光就有調高嘅必要。
至於畫質,就要睇你顔色飽和度調到是否自然,幾濃,幾淡,都對影像畫質的自然狀態有影響。除佐飽和度,影像來源都有影響。數碼廣播頻道系目前最好嘅,因爲本地全部頻道都有得接收1080i高清畫面。相比模擬頻道更加清楚。
Ed.YEO
。。。If 32"(電視) at normal settings, what minimum distance do you feel good normal for eyes?
照以前光管(CRT)電視/投影技術建議嚟講,一般上建議都係電視尺寸嘅兩倍半。但係由於宜家液精電視背光嚟睇,可以減少至一倍半至兩倍呱。。。
如果你有留意,公司内使用32寸電腦屏幕嘅同事,唔係做工程設計嘅,就係一屏幕開幾個程式視窗。32寸屏幕一分割,各個畫面視窗就自然變少啦。。。目光專注就無32寸咁大啦!
super365
SHARP 32" 280x I have seen the real TV before, there is a long horizontal plastic cover at bottom of frame about 4 cm protruding downwards seems to guide soundwave towards front, salesperson told me is for speaker sound. Maybe sound better but seems take up space. Just sharing info.
ralphlauren
