waaa why does the ti makes so much difference?
just mark up locally
higher performance
Rmb, not to hoot just because higher performance. Think about your usage.
Likewise 3GB vs 6GB
Usually 1 monitor 3GB is sufficient.
higher performance
True that it has higher performance but it is almost $400 difference
erm i dont get what you are trying to say
The perf difference isnt a lot.
Its some difference but nearly any 780 should out perform a reference stock 780 Ti / Titan when decently overclocked
Do you know anywhere sells(Graphic Cards - GTX780-3GD5 - ASUS) this type? cause it looks way much better
This is the reference design which performs much lousier and hotter. They dont come like that anymore
Oh haha okay thanks! but they look awesome with that glowing green "Geforce GTX"
It looks nice yup but its smaller than custom pcb models and performs at lower levels. If u seriously want it can get from amazon. Locally only 2nd hand
Well since its lousier and unable to get from funan i might as well get 780 DCU ? funan can bargain right?
Idk leh most ppl dont buy from funan. Dc2 is not bad i used to own
Apparently my pc is a stock pc Its ASUS CG8480(Desktops - ROG CG8480 - ASUS) You can check it out here! But my mobo is spoiled lol.. unless i get back an LGA1155 socket Mobo
But performance wise Is it able to run all games that are currently available at max settings highest MSAA and 1080p at 30fps and above?
Quote: "It stated 3 years on site local warranty (Singapore)"
You might get them to service and repair the M/B
Stock? How come yr 700W But power supply is ONLY : 500 W
Can that casing support longer length GPU card? Airflow?
