Sony Android TV
popdod
any one have issues with the Rss player?
my sony x9000e can't load the rss allrss.se/dramas :(
popdod
Mine is working fine too.
You need to install RSS player TV version.
I download the rss player ver1.0
But when I add the channel allrss.se/dramas.
It prompts “ invalid rss link “ :(
Anyone has the same problem for Sony X9000e?
Pl8888
No need to tweak , u try the link if still cannot means u need to get another RSS version
or u can download Adrama from google playstore
Dr.Vijay
Administrator
Administrator
Well said.
Just like those high refresh rate discussions - if you can't perceive the difference, might as well save money and or focus on other creature comforts to make the decision.
Even putting Q7F and Q9F together. I too find hard to guess which is full array.
I guess it may only very well with certain movies or under HDR.
So important, buy The one you like best and price fits your pocket. Rest of thing to compare is like smart feature, design, and after sales services in case you need it.
Pwindsor
Hi all,
Just throwing my purchase conundrum out there to see if anyone has some good advice...
I’m considering a new purchase and have always had a bias towards Sony or Panasonic...
What do you all think are good deals??
65” X90E $3700 (display set)
65” X90E $2650 (Para Import)
65” X93E $3350 (Para Import)
55” X85F $2649 (w/ 290 soundbar)
65” X85F $3265
Also, how do you all think the 2017 Sony’s compare to the 2017 Panasonic’s? Specifically the 58” EX750??
Many thanks in advance!
precise
Just bought Sony 65 x85f at comex display set plus z9f sound bar. Total damage 3.6k.
Aim for display set to give you saving if you dun mind.
