Sony Android TV
kero89
55" X85F with free sound bar $2399. - $200 if not taking sound bar. Is it worth for this price?
Well it does looks visually nicer compared to Samsung NU7100 that I was aiming but price is a bit on the high side for my budget. Didn't have time to look at X75F but salesperson was more keen to push the X85F deal which was advertised as $2899 on the banner
sunnycrowe
Planning to buy a 65 "inch android TV... 85f or 75f, which one is more value for money... Appearance wise, the 85f looks sleeker.. 75f bottom frame looks thick.. Price wise 85f more ex
sunnycrowe
Recently My sony tv cannot play YouTube. It shows the logo and jam there. Is it YouTube no longer can Play on TV?
cscs3
Power off the TV from main power switch. Wait a few second then power on and try again. Common Android OS issue. (Need a reboot).
cscs3
It happens on my Samsung tv instead , my android tv so far no issues even though is older then the Samsung �� especially web browser
They are also Android base.
It all depend on how frequently you used.
It was reported everywhere. Use keyword sony tv youtude hung as a keyword!
https://productforums.google.com/forum/#!topic/youtube/cC8P9r2JRaE
https://community.sony.ie/t5/other-...-startup-screen-sony-kdl-40w705c/td-p/2400802
https://www.sony.co.uk/electronics/support/articles/00197899
Pl8888
xiangzeng
Do you use youtude from TV directly or casting youtude from mobile to TV?
Usually I cast it from handphone. Playing directly from TV is OK.
many days ago, I noted Youtube took too long to load up on sony tv. But, last few days, I have been able to view videos with minimum time used for loading and really enjoying a lot now.
cscs3
How does Sony compare to LG ? Looking at 65 inch
Basically Sony non OLED TV use Samsung panel. Personally if you ask me to choose between Sony vs LG. I would pick LG. Mostly due WebOS as I find it is much user friendly vs Android.
